Posts: 1,224 |
Dirty MAF, clogged fuel injectors, dying O2 sensor. All could hurt MPG.
You should also check your plugs, air filter, and fuel filter.
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 536 |
Originally posted by ButtonPuncher: Dirty MAF, clogged fuel injectors, dying O2 sensor. All could hurt MPG.
plugs, air filter, fuel filter, and O2 senser were just replaced recently. im sure my injectors and MAF arent in the greatest shape anymore seeing as how they have 213000 miles on them.
whats whould be the best way to go about cleaning the injectors.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 5,143 |
Originally posted by striker2: Originally posted by ButtonPuncher: Dirty MAF, clogged fuel injectors, dying O2 sensor. All could hurt MPG.
Seafoam works really well.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,224 |
Originally posted by striker2: whats whould be the best way to go about cleaning the injectors.
With that many miles, I'd replace them. If you don't have the cash, find a shop that can clean them. This involves removing the injectors, hooking them up in a jig, and running pressurized cleaner through them. The pour-in-the-gas-tank cleaners are only really good for minor buildup and must be done on a regular basis to work.
When your injectors get gummed up, the fuel doesn't come out in a fine spray anymore. Instead, it comes out in drops. Not good.
Contact Bill J. for a price on new ones. He should be able to get you a great deal.
Also, clean your MAF. It can be done in about 15 minutes.
HTH, BP
