#1512046 02/25/06 02:32 PM
F
F
I'm going to install a new roush sway bar soon . I just ordered some end links from Stazi . Is there anything else I nee to get before installing like: better urathane bushings or other mounts ? Can anyone send me some pics or links for this?
Thanks
#1512047 02/25/06 05:33 PM
Poly bushings from BAT. And you may want to box in the subframe, but it's not always necessary.
#1512048 02/25/06 06:33 PM
Originally posted by SVTfrog:
... box in the subframe, ...
Critical if it's not done yet & you plan to push your car a bit. Last thing you want to happen is to have a tab snap off while your in a hard turn. INSTANT DISASTER!!
I would go to a suspension or performance specialty shop if you have one in your town, or a welding shop. The suspension shop will just know what needs doin', a welding shop will give you super-beefy overkill bracing. Either way you're good. Welding shop will be cheaper.
#1512049 02/26/06 12:59 AM
Get a subframe from bradness
JD a.k.a Fingers "Don't Panic" '98 Contour GL 2.0L VCT ATX 88k '98 Contour LX 2.5L MTX 120k Street racing can kill just less of a chance with a 2.0
#1512050 02/26/06 02:03 PM
F
F
Would I need the mount that goes to the sub frame in thr pic above ?
#1512051 02/26/06 04:15 PM
Hmmm. Not sure what your asking. The picture above shows the 2 alignment pins (new looking subframe) with the exhaust hanger (the brown looking thing, kinda sticking up off the new sub) on the hanger arm. The old subframe next to it has the control arms and swaybar still installed. Both parts r upside down.
#1512052 02/26/06 04:18 PM
F
F
Pic on the right , bottom left side . the mount that goes around the sway bar (not the end link) that has the poly bushing from BAT or where ever.
#1512053 02/26/06 04:37 PM
After the subframe is boxed, if your old mounts (to mount swaybar to subframe) look rusted and weak, you will want to replace them... However I'm thinking you might want to go with a subframe from bradness that has the double bolt brackets, instead of the OEM one side hooks the other side bolts. Even with a beefed up subframe the brakets (more so when rusted) want to rip out with a heavy rearswaybar. It seems the bushings for 21mm bars are a tight fit. You could have this happen.
#1512054 02/26/06 06:13 PM
F
F
bad pic can't see s#$% ,anyway what is this mount called so I can order 1 .
#1512055 02/26/06 06:45 PM
Swaybar bracket, they are $$ 40-50 for 1. I would opt for the double bolt mod...
