Page 2 of 6 1 2 3 4 5 6
#1511973 02/25/06 11:05 PM
{TH}NOT!!!!....they are designed to keep intake gas VELOCITY high to keep cylinder filling at max re:better IMEP and cylinder scavange!!!!!!!!!..And the initial design was by Porsche not Watson.
#1511974 02/26/06 02:12 AM
the initial design yes...
but watson made this. If porche designed it then why did watson make one?
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese! diamond pistons for 3.0/forsale #702 of 2150
#1511975 02/26/06 02:25 AM
9
...post a pic of this on the engine if you could...i remember seeing pics at one time or another
#1511976 02/26/06 02:37 AM
W
W
All the principles behind the old tech and new tech are the same and so the experience is helpfull. Sometimes there are just new ways of looking at things, such as with the manifolds. Most of what you were talking about sounds like a pretty good plan though.
#1511977 02/26/06 03:09 AM
this was my 3.0 block and 2.5 heads.
#1511978 02/26/06 04:40 AM
First off, flow is turbulent pretty much everywhere in the intake. There's no laminar flow in a system like this. It's pressure and velocity changes that designers try to minimize. Ideally the air wouldn't have to make a bend like it does, but it's far more important to get the length right. Packaging then dictates that it have bends. Variable intakes are now a pretty common thing on more potent engines, but it was fairly new, and quite an impressive feature on the original engine. Exhaust and intake both work best when they are long and small diameter at low revs, and short and wider at high revs. This intake, as you can see from the tubular pictures, delivers air through narrower, long tubes until the secondaries open, then through both them and the slightly wider, much shorter secondary feeds. Without the secondary design, the engine would just die at low revs. Imagine if the torque curve at 4k continued all the way down, without that hump... it would be pretty lousy at low revs, like most engines of this displacement.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1511979 02/26/06 05:50 AM
Mustang Offline OP
I see your points Consider a manifold with a very large central "log" (like the cobra intake). Run the primary runners underneath this log and have them enter the log on the opposite side. The secondaries can be a straight shot from the bottom of the log directly into the LIM. I know design considerations dictate this type of manifold wouldn't work in an OEM situation as it'd be too tall for a production vehicle. Aftermarket? maybe This type of manifold would eliminate most of the sharp bends that are inherent in the stock svt setup.
#1511980 02/26/06 06:12 AM
Watson created that for some CEG'er (or maybe a NECO Cougar guy). This UIM (below) was the original Porsche prototype... which is not similar to the Watson. Notice the huge plenums
morbid 2000 Contour SVT (black)
#1511981 02/26/06 06:31 AM
Morbid I have never seen those pics before...where'd you get that and are there more!?
#1511982 02/26/06 05:22 PM
W
W
Actually, your part about turbulent air in the manifold is not correct in all cases I'll wager.
Laminar flow can occur in any shaped pipe or trough or whatever, even a rough surfaced one. The flow in the middle will be highest and then velocity will drop off as it gets closer to the walls. This indicates that the fluid nearest the walls doesn't even move and forms a static monolayer against the wall surface.
It is the velocity that makes the flow transition to turbulent.
So there are two main factors, velocity and surface roughness (shape) that affect when and how laminar flow transitions to turbulent.
