#1510288 02/23/06 04:11 AM
N
N
My friends,
I need a good mechanic in NJ that does work on SVT tours. The green machine is suffering from a bad wheel bearing on the right side. I need to have this fixed because the noise is driving me up a wall. Someone please help and tell me that there is someone out there (other than a dealer) than can work on the car for relatively cheap.
Although my mechanical skills are extensive, fixing this is beyond my capabilities. If the person is credible they'll get additional work from me as well (rotors, struts, and a good tune up).
Recently had the heat blower resistor go, these forums helped me find out what was going on.
Help please.
1999 Contour SVT in Green
#1510289 02/23/06 04:23 AM
i cant help you with any mechanics in the NJ area, but this post (as well as many others...mine included), gives me an idea
we should make a comprehensive database of reputable mechanics in our areas. something we can refer to if we have questions like thses. ok, im done being productive for the day lol
ok...back on topic
kevin m 98 T-red mystique gs zetec ATX | my ride |
#1510290 02/23/06 04:46 AM
N
N
Which is surprising that it hadn't been done already. I say you bring it up with the Master CEG'er. We should have a list of reputable shops.
But nonetheless. I still need help.
#1510291 02/23/06 01:59 PM
i too am in need of a new wheel bearing ... i believe mine to be comming from the drivers side rear... it is driving me crazy as well... Altho its not a hard job... All you have to do is remove the spindle and then take it to a machine shop or some where that has a heavy duty press and press out the old and in with the new...
I have a quick question tho... does it sound like a kinda metal on metal type grinding sound??? thats what mine sounds like n i was woundering if in fact it is my wheel bearing and not like my caliper sticking or something... I havnt looked yet... I've been living with this for about 2 weeks now and i cant much longer lol... Also i've heard that if its say the front drivers side u jack up both sides of the front end put it on stands and if the front tire wiggles then that means the wheel bearing is bad is this true??? thats just what i've heard i have never tried it... i've had to replace wheel bearings in some of my hondas in the past but never done one on a contour... so it maybe alittle more work that hondas but i doubt it...
jason
#1510292 02/23/06 02:13 PM
i have never hear of a wheel bearing sound like metal on metal. I jsut had to replace my front brakes and sometime I could here a constant metal on metal grinding sound at low speeds. I had gone through the lining on the pad on one side, new brakes and it was all set
#1510293 02/23/06 03:20 PM
i just put new rotors and pads on my car about a year ago or 12k miles tops. I didnt replace the rear pads tho but everything else i did. The rear pads then looked fine but before i go ahead and put a new wheel bearing on it i will check out the rear pads maybe thats my problem im not sure i havnt looked since the noise started...
jason
#1510294 02/23/06 06:02 PM
I had a wheel bearing go out on me so bad once it was almost as loud as my exhaust system before it was fixed!
They can be loud, and irritating
#1510295 02/23/06 06:25 PM
Cool Toe Chris
Cool Toe Chris
My mechanic since I've owned the SVT has been All American Ford in Hackensack. They have treated me and the other CEG/NECO people I have sent over, right. They are a little expensive, but do good work. Talk to George W. there and tell him I sent Chris A. sent ya!
Chris NJ 98.5 SVT Silver Frost
#1510296 02/23/06 07:54 PM
I did my own wheel bearing a couple weeks ago. I was under extreme supervision from my mechanic, BUT I DID IT :-D
Brett The man thinks its best for everyones safty if i dont drive for 6 months '95 Moonlight Blue Contour (ITS ALIVE AGAIN!) MODS: Knauberized,Reverse Indiglo Gauges,LED's,AEM Intake,Rust holes for more power!
#1510297 02/23/06 08:22 PM
9
I did mine a few months ago... That was a fun job. It took a 5lb. sledge hitting the bolt that holds in the ball joint to break it free... I ended up pulling the whole control arm off with the knuckle then pounding the bolt out... What a pain.
Brad (the_spy_guy) had his done at Sears and it was like $160 I think. Pretty good deal, especially considering it cost me $75 to have the old bearing pressed out and the new one pressed in.
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
