Posts: 68 |
say i have my transmission sitting on my garage floor with the shift tower removed.
say i can see the LSD.
say the tranny currently sits in "neutral"
should i be able to spin it freely? or does it just not move until enough torque is applied to it.
thanks
Cougar is no more, parts for sale.
Built escape 3.0 w/ 8.5:1 pistons, PnP heads, ovalport/mazda6 cams, SVT manifolds, the works
entire car for sale PM me if you want a part!!!
Posts: 9,065 |
Originally posted by Instigator: say i have my transmission sitting on my garage floor with the shift tower removed.
thanks
how are you going to move it?! Turn it with the axles in place or what, stick your hand in there and spin it?!
Posts: 68 |
i was going to try with my hand or another obect small enopugh to fit. if that didnt work, stick and axle in and try.
it should rotate, correct? i havent tried yet because i am trying to diagnose the problem if my car not wanting to move one possibility a a time.
Posts: 536 |
if its in neutral and you spin the input shaft the differential should not spin.
so in a sense they should spin independently when in neutral.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 68 |
yea i kinda thought that. thanks, ill take a look at this now.
Posts: 9,065 |
Maybe it has something to do with you retro-fitting the zetec FD on there...
Posts: 68 |
retro fit? i dont understand.... the stock FD came off and i put the zetec one on.......simple swap of ring gears......
Posts: 718 |
uh oh....you didn't change out the pinion gear?
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 68 |
trevor (fastcougar) said that with later MTX-75's (2001-2002) i didnt need to worry about the pinion gear. i dont know if it brings anything else up, but when my dad and i pushed the car in and out of the driveway, it was EXTREMELY difficult. like it took four of us to push the car out of the driveway and into the garage, and all of us were trying really hard to push it.
Posts: 4,970 |
Yikes, my driveway is sloped and I have pushed my car up it with somewhat ease..... all by myself
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
