Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 759 |
I would have it turned. I have the same issue with my "low milage" '03 Escape engine. You may want to try polishing the journals with some Crocus cloth. I tried this but can still feel some of the scoring with my finger nail. Crank is going to the machine shop this week, and I will also have to pickup the corresponding bearings. I picked up stock size before opening up the engine
Posts: 21,197 |
Well then it's another $90 for all the bottom end bolts. Better than a new engine 20k from now though. Might as well do the mains as well while you're in there. Not what I wanted to hear. I guess I'll try the cloth. Any ideas on crank turning pricing.
-'96 SE MTX 3L
Posts: 5,810 |
Depends on the shop, $75-$100 is about what it went for in Tucson for a minor polish job like that.
See My Mods
Posts: 21,197 |
Can you just have it polished and use the std. bearings I have?
-'96 SE MTX 3L
Posts: 9,065 |
Originally posted by todras: Can you just have it polished and use the std. bearings I have?
you MAY need to plastigauge it...idk
Posts: 5,810 |
If you pull the crank to polish it they will 'Mic' the journals and tell you if new bearings are necessary. Honestly, if the scratches have a depth that is less than the oil thickness during operation then you can just leave it alone. By this I mean there is a design range for oil clearance. As a rule of thumb if I need to do a budget overhaul I just determine if the grooves are say half as deep as the oil clearance design thickness and then if so then I'll just run it otherwise I'll get it turned.
Judgement call you know, Very few cranks on moderate and higher mileage engines will come out with perfect journals anyway and at times you have time or cost constraints and will just install new bearings for peace of mind.
See My Mods
Posts: 21,197 |
For future reference TH says.
...advice/old test.Rub across the main and crank journals with a penny or copper coin....if they leave a copper deposit in grooves then the crank needs a reground and oversize bearings.Watch out with the oilways too....Don't forget the 'sand in block' issues of a LOT of Escape 3.0 and some other 3.0 blocks....lot of used 'junk' out there....with sand in the main feeds to the main bearings....
-'96 SE MTX 3L
Posts: 10,015 |
I would try hand polishing it before going all out and having it returned.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
I am. Found this advice on a web search.
Polishing crankshaft journals:
1) Get a 30" length of leather shoe lace. $3.50 at Wal-Mart's outdoor dept. or any shoe repair shop.
2) Get the appropriate sized OD mic that reads in .0001" (tenths), eBay $15.00 or so. Starrett, Brown &Sharpe, Mitutoyo, etc. Get a good one. It'll last you until the second coming or you loose it in the divorce decree whichever comes first.
3) Get one (1) sheet of crocus cloth. $1.50 at your local FLAPS. You may need to call around some. 3M makes it and ALL auto parts stores used to carry it. In the olden days it was 50 cents per sheet. Keep looking; you'll find
some. One sheet will do about 5 cranks. FYI crocus cloth is jewelers rouge (iron oxide) on a cloth backing (like emery cloth) and is used to polish jewelry.
It has the smallest (finest) grit commonly available for polishing anything.
4) Get a wooden paint stirer at your local Home Depot/Loew's store. Get three; they're free.
5) Get a flat piece of 3/8" steel or a flat file that will fit between the throws of the crank. New file $10.00. Any old worn out file flat file will do nicely. Cost = free.
6) Mike each crank journal (both sides and every 90* around it. You want to know up front any taper and out-of-round condition of each journal before you begin. Write the results down for each journal !!!!!! Don't ASSUME anything.
You 'll never remember what they were after you started.
Depending on the length of time that the crankshaft was left in the salt bath has determined how deep the nitriding is. Usually it is only .0002" to .0003" deep (about 1/10 the width of a human hair). You should only need to take
less than .0001" off of each journal to make them shiny. Thats 50 millionths per side here! Even if you take .0002" off of them its still only .0001" per side so you're still OK.
7) If you have a lathe use it to hold the crank as you spin it at high speed for the mains. Nice but not necessary. Be careful here! Use the crocus cloth backed by your free paint stirer and then the file. The file just lets you
push harder and control the cutting action of the CC. The corcus cloth will do the polishing of the journals W/some light oil. The idea is to get the journal shiny and not tapered. Stop, wipe the journal clean and measure it often.
If you find a taper (or more likely you start to make one) push harder on the big side to take it down to size.
No Lathe, No problem.
8) For the connecting rod journals tear off a strip of crocus cloth and using the leather thong wrap it around the journal twice so that it completely holds the CC on and both ends of the thong comes back to you. It helps here if
you use two pieces of old broom handle to make handles like the old pull starters on lawn mowers. Your call here.
9) Add some light oil and polish away by pulling the thong back and forth causing the CC to spin completely around the journal(s). Check as you go! Write the diameter(s) down!
10) Do the same for the mains if you don't have access to a lathe. Be thinking about getting one though. They are almost as handy as money. Actually handier on late Sunday afternoons and just before all final late night thrashes!
Been there, done that, got many T-shirts!
When all of the journals are shiny record each diameter so *IF* you have to selectively fit bearings you know EXACTLY what you need and where you needed them.
Don't forget to clean the crankshaft completely and grease the nice shiny journals IF you are NOT going to rebuild the engine immeadiately.
Cliff notes:
Get some Crocus cloth from a local Napa, get a shoe lace and wrap it around the crank and cloth twice so it will polish evenly.
-'96 SE MTX 3L
