#1508735 02/21/06 01:33 PM
8
864X4 Offline OP
I recently replaced the Bank 1 upper O2. Then after about 3 weeks the CEL came on again and gave me the codes 171 and 174. What would cause both banks to run lean. I checked my fuel pressure and it is right at 40-44 idleing. I have cleaned my MAF, how can I test the MAF?
1998 Contour SE V6 MTX-75 Mostly Stock 1986 Ranger V6 4X4, the only mod: weight reduction by rust.
#1508736 02/21/06 02:32 PM
Check for a broken hose, leaks at gaskets near the throttle body, EGR valve or exhaust.
From TSB.
Edit. From TSB. Do the cheap and easy ones first.
P0171 - System Too Lean (Bank 1), P0174 - (Bank 2). The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The code is set when the adaptive fuel tables reach a rich calibrated limit.
Fuel System:
�?· Contaminated fuel injectors
�?· Low fuel pressure or running out of fuel (fuel pump, filter, fuel supply line restrictions)
�?· Vapor recovery system (VMV)
Induction System:
�?· MAF contamination
�?· Air leaks between the MAF and throttle body
�?· Vacuum leaks
�?· PCV system concern
�?· Improperly seated engine oil dipstick
EGR System:
�?· Leaking gasket
�?· Stuck EGR valve
�?· Leaking diaphragm or EVR
Base Engine:
�?· Exhaust leaks before or near the HO2S
�?· Secondary air concern
Powertrain Control System:
�?· PCM concern
#1508737 02/21/06 11:43 PM
Best way is to get a real time scanner, preferably one with data logging.
#1508738 02/22/06 12:08 AM
8
864X4 Offline OP
what one would you recomend? I was thinking of getting the one over here:http://www.obd-2.com.
#1508739 02/22/06 12:10 AM
Go for it. Works great.
#1508740 02/22/06 01:58 PM
I have that one and have used it for around 4 years.
Once you get the hang of how it works and what some of its advanced features are, it's about as handy as a shirt pocket.
Don't be surprised if you end up doing an UIM/LIM rebuild to replace leaky gaskets.
Steve
