Posts: 8,143 |
Originally posted by Tour4reak: whats the point of lifing it that high if the diff's are still 1 foot off the ground
that is something I have yet to understand...that truck could be about 6" lower and have the exact same amount of ground clearance. those huge tires are about the only thing upping the clearance on that truck.
but whatever, I'd take a lowered car with some nice stiff suspension over that anyday.
Posts: 2,446 |
Originally posted by ZetecNinja: Originally posted by Tour4reak: whats the point of lifing it that high if the diff's are still 1 foot off the ground
do you not see how close the tires are to the fender wells? if the truck was any lower than when the suspension flexs, the tires would murder the fenders.
Posts: 273 |
Originally posted by Thinkmoto: Stock cummins with a 6speed will see 20-25mpg easily even 7.3L powerstroke fords can get theat with the 6 speed. Maybe with 44inch mudders it might not but it'll do alot better then you think.
Yeah, after more research I did find some numbers in the 20-25mpg range, but obviously there's no way this truck could do that.
"Mod your car tastefully because other people have to look at it."
-Me
Posts: 8,143 |
Originally posted by GIT-R-DONE: Originally posted by ZetecNinja: Originally posted by Tour4reak: whats the point of lifing it that high if the diff's are still 1 foot off the ground
oh, so thats what the 6" lift is for...to prevent rubbing.
i always thought it was for those parking lot speed bumps.
Posts: 4,970 |
Stock cummins does alot better then 15mpg. I saw gains of around 3-4mpg with my duramax. That was running stage 3 edge juice with attitude. adds upto 125hp/325lb ft if i remember correctly to stock power numbers....so 400+hp/800+lb ft and around 20-21mpg for a dmax. Stock cummins with a 6speed will see 20-25mpg easily even 7.3L powerstroke fords can get theat with the 6 speed. Maybe with 44inch mudders it might not but it'll do alot better then you think.
I have to chime in here! Turbo diesel power is the only way to go for trucks and SUV's. Tuning and small mods net huge numbers, and they also net a MPG bump in an already efficient setup like Thinmoto is pointing out.
Also, you can run biodiesel in them as-is, and look to our farmers to fuel them.
There is a point to where lifted trucks are simply grocery getter death traps (for other people, that is). But I do like a small to moderate lift on trucks/SUVs. But, only a lift that improves a vehicles abilities and not make them a top heavy and untrailworthy POS. There is such thing as too big.....
Edit:
Personally, I would go about this big. This Excursion is a perfect example of what I would want to buy (minus the butt ugly grill guard!), if I weren't saving for a home. Turbodiesel for power and good MPG, small lift, nice wheels/tires.....
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 21,653 |
A coworker has a white excursion similar to that. His has a ~6" lift and it looks like slightly bigger tires. Though his is gas, so crappy gas mileage but he doesn't care. Has TVs in it and a nice system. Good for his 5 kids I reckon.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
