#1506226 02/17/06 10:35 PM
blakjak Offline OP
is there a way i can have the key come out when the car is in neutral?
caleb d.
-Contour's dead, but is being revived...
Originally posted by CSVT1214:
Originally posted by ford zetec2:
after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
#1506227 02/18/06 01:21 AM
You'd have to find the solenoid that prevents the lock cylinder from turning off, and hook it up to the neutral safety switch (the one that allows you to start the car in park and neutral).
Otherwise you can wire it to where you can remove the key while the car is in any gear.
My old 96's cylinder was worn out... I could pull the key out in any position (like I could take the keys out while it was still running).
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
