Posts: 21,197 |
1993 Taurus SHO 5 speed Car has 160k on it & I want to get rid of it ASAP and I'm willing to let it go for 2000 OBO. Car has 160k on the clock. This is nothing on an SHO engine if it was maintained properly. A few documented cars on the net have 300k and still going strong. It needs a new oil pan gasket to stop a slight leak and a new A/C compressor. I have a spare a/c compressor that can go with the car. The upper 60k valve shim has been done at 107k which was when I bought it. Virtually no wear on the valve shims. At that time of course new Motorcraft plugs and wires. I just replaced the starter that has a lifetime warranty. I have almost all receipts for the car including original window sticker showing 27500. Also have a dyno plot of 190hp/191tq to the front wheels showing how strong this car was at 110k. List of things that have been done... Driver side ball joint, new end links all the way around, new sway bar bushings, car has largest sway bars, put KYB struts on at 112k, radiator was replaced as well as the upper rad. hose. I have replaced some vac lines that looked old, fuel pump was replaced for peace of mind, has a Dynomax exhaust on it, clutch was replaced at 100k by a Ford dealer. Idle air control valve, mass air flow, throttle position sensor, and a couple coolant temp sensors. I have a new IAC that can go with the car as well as spare motor mounts. I had a spare motor but I junked it after tear down and kept the mounts because I know someone would want them. The trans. drain plug modification was done so you don't have to take it somewhere to get the trans fluid pumped out. Can change it right in your driveway. Rear brake lines have been replaced as well as rear calipers. I just looked at the pads and they have 50% life left. It has Bendix Titaniums. The front rotors are a little warped. The front bumper and rear bumper have some scrapes but nothing is gouged. I have the original window sticker and a ton of the receipts from the guy I bought it from. The car has black split leather/cloth int., moonroof, and has tinted wondows. The car has slight rust bubbling around the tops of the driver door and the edge of the trunk. The only things that hasn't been replaced are belts, alternator and the water pump. This starts and runs like new. No smoke out the tail pipe and doesn't burn oil. todras@yahoo.com cell(616)304-4283 pics http://www.fototime.com/4225BCDD902A480/orig.jpg http://www.fototime.com/AED76175FFD5BEB/orig.jpg http://www.fototime.com/E81E4C1FEE9B7E6/orig.jpg http://www.fototime.com/66BF720ED0E6976/orig.jpg this is in Grand Rapids, MI
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 166 |
i have 3 michelin pilot tires---perfect for track days
TRACTION:AA
TEMP:A
TREADWEAR:220
the tires have about 200miles on them, they normaly retail for around 175-250(depending on where you get them), since the milage that they have on them is track life i am only asking 50 per tire(seeing how local pick up will more than likely be arraged otherwise 75 per tire) PM me or call my cell if interested
chris
(248)249-3053
[mod]DO NOT POST PRICES[/mod]
99' silver smokin' csvt
born on march 18 99' #1491 of 2760
burninrice no more
Posts: 1,978 |
If anyone wants 4 17 x 7.5 BBS RX chrome wheels.... Two are bent beyond repair, but would make a bitchin table, xbox stand or something. The other two are perfectly normal. Brand new they sell for upwards of 300 dollars each... someone could most likley sell these on ebay!
Ill take anything for them, PM Me
Alex
'99 SVT Contour
Posts: 726 |
Selling:  1. SP Motorsports brake kit - KVR crossed drilled rotors, KVR carbon fibre pads, SS brakelines. (posted in classifieds) 2. A pillar gauge pod painted in dark blue to match the dark blue interior of my svt. 3. Autometer Phantom vac/boost gauge 4. Autometer Phantom electrical oil pressure gauge (not sure if I can salvage the sending unit) That is all for now. -Tim
Tim
Ex - ContourPower
2001 Saab 9-3 Viggen
Posts: 2,086 |
Anyone know of a decent priced/mileage Contique for sale around the Ashland, Mansfield, Wooster area? If so shoot me a PM. Looking for stock as it's for my g/f, she recently drove my Mystique and now wants a Contour as her 92 Grand Am keeps having issues. Thanks in advance guys.
Jason G.
Born: 11/96
Posts: 626 |
have a pair of subs in box for sale. check my ad here in the classifieds.
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Selling:
Konig 18's Blatant's with BFG Euro Ta's and FSVT Euros wrapped in Falken RT-215's
will trade both for a set of sweet 18's or 19's with tires
or sell seperatly
Posts: 54 |
WTB : BIKE RACK for 99 CSVT
[mod]don't change the title in your post[/mod]
-- SAY NO TO RICE --
# 2002 out of 2760, RS-7 18 inch Bronze Enkies, Dual Magnaflow Exhaust,
samochod
Posts: 103 |
00' csvt for sale, 74k , black on tan, all stock, great conditon, make offer.
Black '00 CSVT #4 of 2150
K&N ru-3530, BAT MTF, Magnaflow exhaust, MSDS headers, and optimized y-pipe.
Back In Black
Back In Black
Posts: 3,119 |
For Sale: Four (1 Set) 19X7" ICON Split 5-spokes NEW Still in box. Specs: 4X108mm, 42mm offset, 19.5lbs Here is a pic:  PM me with questions. -Mark
