Page 1 of 8 1 2 3 4 5 6 7 8
#1504194 02/15/06 06:43 PM
Can the contour SVT with modifcations be pushed under 13s 1/4's? How can this be accomplished without Nitro?
#1504195 02/15/06 06:46 PM
1)Try the dyno/drag forum
2)Sure, if you gut it and make it rwd. The theoretical limits of the chassis/engine have been covered and re-covered. A turbo 3L has the power, but the chassis would need a LOT of work to put it to the ground.
3)Read the FAQ and forum info before posting. Doctors are literate, right?
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1504196 02/15/06 06:47 PM
four words:
Ebay resister chip, Tornado
#1504197 02/15/06 06:49 PM
#1504198 02/15/06 06:49 PM
If its possiable to convert the car to rear wheel could you not convert it to all wheel? After all thats one thing that would greatly help it get its power to the ground.
#1504199 02/15/06 06:52 PM
My advise to you...is to stop posting imediatly and start researching using the search funcion.
#1504200 02/15/06 06:53 PM
About 6+ years of info on contour.org. That should keep you busy.
#1504201 02/15/06 06:53 PM
Y
Y
WTF is nitro? Isn't that what people dump into their gas tank and think they gained 50HP?
Without F/I, it's going to be near impossible to run 12's with the Contour setup.
Mark
#1504202 02/15/06 06:56 PM
Adding the driveshaft and extra differential would get in the way of the flux capacitor.
Seriously, someone will get a contour into the 12s at some point. How much money you wanna spend?
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
#1504203 02/15/06 07:19 PM
Originally posted by pole120:
four words:
That is too funny.
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
