Posts: 338 |
Hey all. I have searched and come up with a lot of the same kind of stuff. Any way I need some answers, opinions I have a 3L block from 02 escape bored .020 over, already filled for use as hybrid, I have crank and rods, no pistons, svt heads with new valves and 5 angle valve job, also I have the timing components needed for hybrid.
ok, the plan is to run N/A high compression with future nitrous use. what would you recomend for C/R. And what pistons should I use, OE or Aftermarket, what C/R will I get with .020 over OE piston with the svt heads
Next I need recomendations on an intake to use, I can get a metal taurus intake for dirt cheap, is that a split port style or oval port, looks like Stazi's for reference.
Next I know to get the newest oil pan from bill, but there is no windage tray or oil pump pick-up with the block, what should I get Next what brand head Gaskets should I use
Next Camshaft selection, I have no cams either, sould I use svt cams, 3L cams wouldnt have water pump drive right?
Ok finally this is going in a 95 contour mtx. What will I need for tuning on the OBD1 system, I will need injectors as well, I have a fuel rail, return style I believe. Thanks In advance for all the help and if I missed something searching I am sorry, there is a lot of info I dont know what to use and not use.
95 mystique daily driver
96 mystique parts car
95 contour 3.0L oval port swap in the works
check my classified ad
Posts: 21,197 |
3M4Z-6675-BA Upgraded Oil Pan Set
YL8Z-6622-BA 01+ Upgraded Oil Pickup (req 01+ main studs)
YL8Z-6687-AA 01+ Upgraded Windage Tray (req 01+ main studs)
(In the stickies)
OEM or Felpro.
Fel-Pro Part# HS9038PT 2.5L Head Gasket Set (In the stickies)
SVT
Searching turns up this.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,760 |
How big of a shot do you plan on running and how often? If its 100> I'd go with stock pistons. Nitrous is hard on a motor, but I think Tom's (now Ray's) turbo has proved that the pistons can take a punishment. Plus, alot of its in the tune.
As for the cams, I'd stick with the SVT cams. The juice will make up for what minimal torque is lost down low.
I think the 11-1 compression is reasonable for the go go juice and pump gas.
Ryan
Trollin!
Posts: 6,106 |
Todd, are you suggesting he use the metal UIM? I thought most people were going with the plastic? Bsoelman, if it so happens that you need a plastic UIM, I've got one along with the LIM & T/B that I'll let go for CHEAP!! Just let me know man.
Mark
2000 Black CSVT
Posts: 21,197 |
Originally posted by Y2KSVT: Todd, are you suggesting he use the metal UIM? I thought most people were going with the plastic? Bsoelman, if it so happens that you need a plastic UIM, I've got one along with the LIM & T/B that I'll let go for CHEAP!! Just let me know man.
Mark
Needs more read better skills. He has SVT split port heads.
-'96 SE MTX 3L
Posts: 6,106 |
Originally posted by todras: Originally posted by Y2KSVT: Todd, are you suggesting he use the metal UIM? I thought most people were going with the plastic? Bsoelman, if it so happens that you need a plastic UIM, I've got one along with the LIM & T/B that I'll let go for CHEAP!! Just let me know man.
Mark
D'oh! Getting the 3L threads mixed up already. In that case, I've got some 3L oval port heads w/ cams and the intake manifolds I'll sell him for CHEAP! I know he's using the 2.5L heads, but I don't know if it's because that's the route he wants to take, or if he just came across a block for dirt cheap, and already has the 2.5L heads from his Mystique.
Mark
2000 Black CSVT
Posts: 21,197 |
HE HAS THE HEADS COVERED. Caps for people that need help. Originally posted by BSOELMAN: I have crank and rods, no pistons, svt heads with new valves and 5 angle valve job, also I have the timing components needed for hybrid.
-'96 SE MTX 3L
Posts: 9,065 |
Don't use the OBD-1...you are going to lose your $$ tuning that bugga
Posts: 21,197 |
So is he going to replace all the wiring in the car and PCM Pete? WTF? He can get the OBD-1 tuned just fine for about the same price as 2. Less options with 1 but who cares. Also I hope you have a Quaife planned.
-'96 SE MTX 3L
Posts: 2,974 |
An option for camshafts is CAT Cams, just be prepared to pay alot for the cams.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
