Posts: 261 |
Originally posted by SVTfrog: Yeah, less than a foot of pipe extra has to be welded in.
unless you get the precats..then your fine, but otherwise, yes.
-Contour's dead, but is being revived...
Originally posted by CSVT1214: Originally posted by ford zetec2: after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
Posts: 21,653 |
Originally posted by striker2: mandrel bent is better. gives smooother flow
It's a zetec. Is that extra .25hp worth the cost?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 21,653 |
Originally posted by the other davis: Originally posted by SVTfrog: Yeah, less than a foot of pipe extra has to be welded in.
Put the precats onto a zetec? whatcha talkin bout willis
98.5 SVT
Posts: 536 |
Originally posted by SVTfrog: Originally posted by striker2: mandrel bent is better. gives smooother flow
being as that i got it mandrel bent for free (my vocational school as a bender) yeah it was definatly worth it espically since i plan on putting on a turbo.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 67 |
Nobody knows where I can get the flange for the front connection of the pipe?
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by mcgarvey: Nobody knows where I can get the flange for the front connection of the pipe?
Exhaust shop?
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 261 |
Originally posted by SVTfrog: Put the precats onto a zetec? whatcha talkin bout willis
basically use precats instead of extending. gutted of course.
Posts: 21,653 |
Originally posted by striker2: Originally posted by SVTfrog: Originally posted by striker2: mandrel bent is better. gives smooother flow
Well dang, you coulda dun mine while you were at it.
98.5 SVT
Posts: 21,653 |
Originally posted by the other davis: Originally posted by SVTfrog: Put the precats onto a zetec? whatcha talkin bout willis
I'd rather just stick some pipe in there.
98.5 SVT
Posts: 3,065 |
You can just say that because you have a SVT now.
