Page 3 of 4 1 2 3 4
Originally posted by procyon:
For the 2.5L Contour/Cougar/Mystique:
Use F53E-17A084-DA (service # YL8Z-17A084-DA) for the front engine lifting eye (RH head).
Use XU3E-17A084-AB (service # XU3Z-17A084-AA) for the rear engine lifting eye (LH head).
So where did you find the info?
Procyon is CEGs random know it all...
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢:
I think he means the rear bank being closest to the firewall.
Rear means rear of engine. (flywheel end)
That's contradictory to the previous post....
...because-
Using the front\rear logic you're stating, the rear eye bracket would mount to the LH head, and that's not the case, it mounts right next to the WP on the RH head
Not trying to be a dick, just trying to sort this out so i order the correct part.
Josh
There is a problem with your logic. Unless you have a "one of a kind" 2.5L Duratec engine the waterpump is driven by the LEFT HAND intake camshaft.
RH = cylinders 1-3 = firewall side
LH = cylinders 4-6 = radiator side
...also I don't care if I'm a dick.
Got it.
Thanks.
Josh
I ordered the part..Demon and Procyon are correct
Got mine on saturday
Mine is on the car...works great!
Yeah i got in installed right away, motor goes back in next weekend
Page 3 of 4 1 2 3 4
