Page 2 of 2 1 2
#1500132 02/14/06 03:14 PM
Originally posted by Tony2005:
Originally posted by ToasterOven:
so your saying that there is a leak somewhere after the TB?
Only way to really find the leak is by spraying carb cleaner or propane gas at different places and see if the idle changes "significantly".
That part in bold sounds like a REALLY bad idea to me. I've never seen this suggested before.
#1500133 02/14/06 03:17 PM
That is actually the method of choice for most mechanics as it doesn't leave as much residue.
Edit.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1069776&page=&view=&sb=5&o=&fpart=1&vc=1
http://www.aa1car.com/library/vacleak.htm
#1500134 02/14/06 03:22 PM
2
I used Berrymans or Gumout spray to hunt for leaks. That's how I found the ones in the vacuum ports on top and the EGR valve. The idle will jump a little. That slime you see is EGR/PCV gunk.
#1500135 02/14/06 03:25 PM
should i be thinking about changing my PCV then? my shop teacher said that that is what it sounds like to him
99 V6SE Sport ATX
Page 2 of 2 1 2
