Originally posted by rac74: So would a solid Delrin/polyurethane bushing do the same thing? Also, the only reason I could see having these over a solid bushing is being able to remove them when not at the track so the ride isn't so stiff. Is this why you went w/ them?
Even with solid joints instead of bushings you still get the control arm flexing, that is why I boxed them in. The ability to adjust the preload from daily driving to track conditions or for that matter even having preload at all would not be possible with the bushings and you do notice a huge difference in handling, traction, wheel hop and traction with the bars installed.
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
