Posts: 92 |
Ok my WR headers are being delivered tommrow and plan ok having them in tommrow night sometime.Still haven't found a three bolt flange close by and dont have the time to get one shipped.Just wondering if a local exhaust shop would have them or if they can make one to fit.If they can't make/have one I will stick the factory Y pipe in till I get one but there won't be any flex in the exhaust seeing how I broke the bolts in my factory Y and will have to use regular bolts.Will using the regular Y with regular bolts cause to much stress?Whats the flow difference between a stock(unoptimized) Y and the Weapon R.
Posts: 3,637 |
i didnt think the stock Y bolted to the weapon R's. But yea, Warmonger has a 3-bolt flange, and Trubendz has them. Maybe someone with some more knowledge(Stazi) can shed some light.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 92 |
Yea I sent a PM to war and if they can't make one then I will get his.Just sorrta need car back on the road asap and didn't want to wait for shipping time>
Posts: 3,637 |
you could always just hold off doing the header install for a week...
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 7,117 |
Originally posted by Tourige: you could always just hold off doing the header install for a week...
To do it right, an extra week is worth the wait. One of your local shops should have one in stock to match up to the 3 bolt Y. Otherwise, get QUOTES for the work & have the winning bidder order the part. You may also need them to install an O2 bung.
Posts: 2,116 |
doesn't it take like 2 weeks to get the rear manifold out anyways?
95 SE MTX
svt exhaust
intake
deer killer
Posts: 92 |
Just need the car back on the road ASAP other wise I wouldn't mind the wait.Worked on it for 2 1/2 hours got all done except the 3 bolt on the top of rear manifold,didn't have enough extensions.
Posts: 3,637 |
Originally posted by elraido: doesn't it take like 2 weeks to get the rear manifold out anyways?
2 days.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 5,810 |
Originally posted by GrimmSVT: Just need the car back on the road ASAP other wise I wouldn't mind the wait.Worked on it for 2 1/2 hours got all done except the 3 bolt on the top of rear manifold,didn't have enough extensions.
Well, DON'T fail to put those three nuts on the top of the rear! Make sure you use all 6 nuts and secure the headers good or you will have exhaust leaks up the ass and probably incurr driveability issues.
As far as the 3-bolt flange, I've got it and as soon as you decide you want it, and I receive payment then I'll priority mail it to you and you'll get it in probably two days.
See My Mods
Posts: 611 |
You could just cut the flange off and have a shop weld the other section of pipe onto it. You have disconnects before and after anyway. There really isn't a need for that disconnect anyway.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
