Posts: 1,746 |
Originally posted by waggy73: Don't ask me how I know.
Someone has a bump in their hood...
2000 Contour SVT
SF - #542 of 2150
Posts: 1,899 |
just be glad the positive didnt hit too
Posts: 2,369 |
Originally posted by posthuman63t: Originally posted by waggy73: Don't ask me how I know.
I had one on my stock SE hood from the yellow top. Ended up getting a CF hood anyways and fixing the problem!
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Posts: 624 |
Originally posted by skrilla187: Originally posted by posthuman63t: Originally posted by waggy73: Don't ask me how I know.
Add me to the bump in the hood list, on my SE, still there!
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
Posts: 3,816 |
Originally posted by waggy73: FYI, the Red Top is classified as a "Starting Battery", which means it has more Cold Cranking Amps, and it is not designed to be constantly drained and recharged like a deep cycle.
The Yellow Top is a "Deep Cycle", with less CCA's, but can discharge and recharge with little to no ill affects.
The Blue Top is a hybrid of sorts, more CCA's than the Yellow, less than the Red, but is also a Deep Cycle battery like the Yellow. Kind of the best of both worlds. They are also the most expensive if I remember correctly.
Yellow Tops are also the hybrid you speak of.
The cheap Blue Top, 34M, has the same specs as the 34/34R Red Top, and is just a starting (not deep cycle). The other 2 Blue Tops (D34M and D31M) are deep cycle and starting.
Starting batteries:
34/34R Red Top: 800CCA, 1000CA, 110 reserve
34M Blue Top: 800CCA, 1000CA, 110 reserve
Starting and deep cycle:
D34/78 Yellow Top: 750CCA, 870CA, 120 reserve
D31M Blue Top: 900CCA, 1125CA, 155 reserve
Note that I only listed the best of each. The Blue Tops are still the best, though.
The threaded terminals might be handy if you like to remove your trunk setup a lot. Well, if your battery was in the trunk!
Blue Top:
(click for full size pic)
My current battery (no trimming required!):
Posts: 2,659 |
Originally posted by posthuman63t: Other guys put it in the trunk on the passinger side of the car to help offset the weight of the driver.
What How much do the drivers weight? I have never heard of that before. Either the battery is very very heavy or the driver doesn't weight much at all.
[knocking on wood] Im still on my original car battery gulp!
Knowing my luck, im going to go outside right now and my car wont start!
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 5,600 |
Its obviously not the same weight of the driver, but it helps offset it some.
Batteries arent that light.
Black 1998.5 CSVT
Posts: 2,659 |
true, they are not light but to off set a driver I guess every little bit helps.
99 Contour LX
97 Z24 Cavalier
Posts: 1,746 |
Originally posted by jtour: Originally posted by posthuman63t: Other guys put it in the trunk on the passinger side of the car to help offset the weight of the driver.
haha! I didn't mean it evens out the weight! It just helps...a 160lb driver with another 25lbs (i never weighed a bat) to one side vs that 25lbs on the other side making it equivelant to a 135 lb driver. Sorta get what I can't explain...hehe.
2000 Contour SVT
SF - #542 of 2150
