I feel Guilty, Oh so guilty
Posts: 4,789 |
Originally posted by Davo: The true Patriots fans aren't the ones that think Tom Brady single-handedly wins Super Bowls. It's some of the guys from Michigan who feel it necessary to jock him because he played for the Wolverines.
Right...
-Mitch Hedberg
Posts: 2,445 |
Originally posted by foldthecorners: .
I read something up there about the refs and their role in the game? The Steelers overcame a few bad calls in the Colts' game and were STILL able to win the game. That's what good teams do.. When something on the field doesn't go their way, they should still be able suck it up, keep their composure and try to make a big play to make up for it. Besides that, Everything that I saw the refs call, I saw happen on the field.
You are as blind as they are. It was not a few calls, it was MANY calls including ball calls on the Rothlisburger TD, the two TDs that Darrell Jackson should have had and so on.
That is a 21 point difference in points. Not to mention the non-hold our O-lineman was called for that brought back a reception on the Stealer's 1, Matt hasselbeck being called for an ILLEGAL BLOCK when he was MAKING A TACKLE, and the list goes on and on.
The Steelers are not Superbowl champs.
2000 Contour SE Sport
Originator of the Beowulf Headlight Mod and the Beowulf CAI
Posts: 3,738 |
i know of a trophey that says otherwise
~Andrew
2001 VW Jetta Wolfsburg Edition
20 valves of fury
Posts: 7,392 |
Originally posted by Beowulf: You are as blind as they are. It was not a few calls, it was MANY calls including ball calls on the Rothlisburger TD, the two TDs that Darrell Jackson should have had and so on.
wahhhhh.
btw, it's not a 21 point difference in points. they did score field goals right?
and you think jackson wasn't pushing off?
btw, your coach is a real class act.
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 4,789 |
Unfortunately for Seattle fans, they absolutely are. The push off on D. Jackson was the right call based on watching it at game speed. The replay showed that it was not a forceful pushoff, but at full speed after watching a few more replays, I don't have a particular problem with it. It's purely a judgement call and a good acting job by the Steelers defensive back. I have no problem with this one.
The holding call was not a good call, but whenever an o-lineman gets his hands up above the shoulder, it WILL get called as holding. He knew better.
With the other D. Jackson potential TD, are you referring to the one on the sideline that he was called out of bounds on? If so, what was your beef? I was very curious about one aspect of that play, but found some clarity in the rules that made it obvious it wasn't a TD.
The odd blocking/tackling call on the INT return is beyond me.
The Stevens incomplete pass call was perhaps the worst of the game. Who's to say they wouldn't have recovered that fumble and scored a TD had it been properly called?
Seattle's lack of clock management skills was their downfall regardless of what calls the received.
Like I said, I didn't have muhc of a rooting interest either way and found some of the calls very odd, but Seattle screwed up enough things to not blame an official.
-Mitch Hedberg
Posts: 4,149 |
Originally posted by Beowulf: Matt hasselbeck being called for an ILLEGAL BLOCK when he was MAKING A TACKLE
At least he MADE the tackle! Where was Hasselbeck when Willie Parker torched the Seachokes for 75 yards?
-- 1999 SVT #220 --
Posts: 2,445 |
Originally posted by bigMoneyRacing: Originally posted by Beowulf: Matt hasselbeck being called for an ILLEGAL BLOCK when he was MAKING A TACKLE
Hasselbeck doesnt play defense. he was on the sideline wishing he could have made an illegal block.
Posts: 167 |
[henrietta pussycat voice] Meow Meow Steelers not the meow meow champs. [/henrietta pussycat voice]
Dude...pass the pipe. Catch some balls instead of dropping them...keep your feet in bounds and maybe, just maybe your team will win one sometime.
And it was one touchdown with a push off, not two. Read the rules of football and we can debate it. Last time I checked, both feet need to be in bounds.
Joey
2006 MazdaSpeed 6 Black Cherry
2004 Jeep Renegade Black
2000 SVT Black
#1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
