Posts: 5,600 |
Just get all the gaskets. If you havent ever pulled the UIM/LIM/TB/EGR/IAC then the gaskets on the TB/EGR/IAC will likey tear or fall apart. The Felpro gaskets from Autozone are of equal quality to the Ford ones. The Felpro ones also come in a pack of 4 (two LIM, two UIM) so it can make things a tad easier. Equally priced to the discounted Ford ones, plus you can typically get all the gaskets from Autozone in the same day (though they had to order either the IAC or EGR gasket, not sure. Came in by the next day.). Valvoline carb cleaner works amazingly well for the LIM and TB. It pressure washes the buildup right off, often without even scrubbing. For the UIM you need to get something you can pour in, like Seafoam or Berrymans. On a related note, WEAR GOGGLES WHEN SPRAYING CARB CLEANER! When I was spraying out the back of the TB, the cleaner shot back at me out of one of the groves (like putting a ladle under the faucet) and went straight into my eye. I thought I was going to be blind, and I dont think Ive ever felt pain like that in my life. I had my open eye under a stream of water for like 10 min, and I could feel it all day  I would have felt like such a tool if it caused permanent damage. Goonz, this thread has reminded me that I still need to make me a oil seperator. Thanks for the reminder
Black 1998.5 CSVT
Posts: 6,106 |
Originally posted by CSVT1214: Originally posted by todras: $100! I think a set of 4 UIM/LIM gaskets is $38 at Napa. Average is $40. Autozone can get the Felpro ones too. I don't change any other gaskets. Reuse TB/IAC/EGR.
Shouldn't it be the other way around about reusing the gaskets? I would think the UIM/LIM gaskets would be more reuseable than the TB/IAC/EGR. Don't those gaskets seal themselves after a little while with heat?
Correct me if I'm wrong.
Yep, you're wrong. With the few cleanings I've done, I've reused the TB/IAC/EGR gaskets, and replaced the intake manifold gaskets once.
Mark
2000 Black CSVT
Posts: 5,600 |
Pssh, dont listen to Mark.  Just get new ones. The only harm it could do is lighten you by maybe $20 and you might actually do some preventative maintenance. Big whoop.
Black 1998.5 CSVT
Posts: 4,292 |
Originally posted by Y2KSVT: Originally posted by CSVT1214: Originally posted by todras: $100! I think a set of 4 UIM/LIM gaskets is $38 at Napa. Average is $40. Autozone can get the Felpro ones too. I don't change any other gaskets. Reuse TB/IAC/EGR.
Mark
i'm with mark...i clean my manifolds once every month,(that its on the road) and i've only replaced the upper/lowers once..tb twice and thats it
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 21,197 |
I know of many people having vac leaks reusing UIM/LIM gaskets when they have some age on them. If you have over 30-40k on the gaskets I'd suggest getting new ones.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 7,100 |
Originally posted by todras: If you have over 30-40k on the gaskets I'd suggest getting new ones.
Personally? +1
'99 CSVT - Silver #222/276
Posts: 5,600 |
Originally posted by tour96se: i'm with mark...i clean my manifolds once every month,(that its on the road) and i've only replaced the upper/lowers once..tb twice and thats it
Well you have replaced the originals, so the new ones cant be all that old.
If you have never done it, I would highly recommend replacing all of them to avoid any potential leaks (which will throw a CEL).
Black 1998.5 CSVT
Posts: 1,593 |
Originally posted by Goonz SVT: Originally posted by Oscar Nominated Ray: WTH? $100??
Go through Bill J and get the entire thing for WAYYYYYY LESS than that.
I got everything I needed for $66
Did you go through Bill J?
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 3,637 |
Originally posted by mean'tour: Originally posted by Goonz SVT: Originally posted by Oscar Nominated Ray: WTH? $100??
yea, he did
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 9,872 |
Originally posted by Tourige: Originally posted by mean'tour: Originally posted by Goonz SVT: Originally posted by Oscar Nominated Ray: WTH? $100??
yea, he did
yes I did, this what i said to him
Bill Im gonna be getting this done, I need all the required items like the gaskets, o-rings and what not
$66, great guy to deal with as well
Haroon
