I dont know where to begin...Tony (csvt1214) will also describe as he was there helping me with the clean up..
We did a whole UIM/LIM clean up..new manifold gaskets, egr gasket, TB gaskets..changed the plugs to the autolite P740 or whatever it is..wires to the magnecor 8.5..everything went smooth..only thing we were having some problemm with were the wires..they seem to be very lose on the plugs even though we pushed hard on them to make sure they were stuck on but yet again they would come off with the slightest force which was very odd..another thing that broke was the Vaccum hose that feeds in the UIM, we kinda taped it for temporary untill i can get a new one from ford..I'm not gnona drive it untill i have that, we taped it just so we could fire it up and see if she was normal, but no, somthing had to go wrong
all said and done came time to start, wouldnt start, the engine was turning but no start..Tony and I read up that some maybe used the gas peddle pumping methood so we tried that..nothing..only heard minor pop sounds during the car trying the start..then my battery died after trying to start it for a while..jumped it and then got back to starting it again..it was starting to turn over and finally it did with rediculous rough idle so we kept it reved high for a bit..after almost 5 min we let go so that it could idle on its own for a bit..(we did pull the computer fuse before starting to reset it)..we then took it for a minor test drive to see if kick somthin in the engine..Tony drove and he said he was flooring it with absoloutly NO power..and my exhaust was EXTRA EXTRA loud, we drove it around the block and came back to my house, popped open the hood and saw the front header lit up red
he shut of the car and we smelled somthin burning..luckily there was no smell of gas or anything like that around the UIM/LIM..but that fron header was lit up for a good 10 min untill it cooled down (it was pouring out too) we checked everything, all the wires seemed to have been in place..the wires connecting to the coil pack were all in the right order. I dont get it everything we did was exactly as told in the HowTo's..What got Tony confused was the fact that why my front header was soo hott that it was lit up red?!? It still idle'd rough..after we killed the engine I dare not start it untill i know whats going on, the nearest autozone is like 10 miles so I cant go get a code reading, I know I'll get a bunch once I go back and try to restart it..Tony will chime in on more details..
I dont know what happened? why the hell was the header lit up!?!?and just the front one too, not the back one
