Posts: 5,345 |
Originally posted by SVTmania: "instrument cluster panel lens and cover assembly" Then The last two is with the key to the 'on' position while the dash is doing it's selftest.
No, no, no, I meant take out the lens and cover assembly so that all you see is the bulbs. To determine if the lens cover is different and not for the instrument cluster. That will show where certain bulbs are lighting up when it is on the "on position" and when the engine is running (if the CEL light is lighted up or the airbag light is lighted up). A bulb could be lighted up and you would not be able to see it if the lens and cover assembly (with its spaces for the idiot lights) are not aligned for the instrument cluster.
1996 V6 ATX 96K miles
Posts: 69 |
Originally posted by Tony2005: Originally posted by SVTmania: "instrument cluster panel lens and cover assembly" Then The last two is with the key to the 'on' position while the dash is doing it's selftest.
I see what you are saying. I know for a fact the circuit board on the back is also different because the airbag light uses a LED and a different socket size. The only place the LED will go is the position all the way to the left where the airbag symbol is. But it doesn't work either. I will have to investigate your suggestion.
'99 SVT Contour
Tropic Green
Stock
Posts: 495 |
Originally posted by pole120: Originally posted by Tony2005: I wonder if it could be a Mondeo instrument panel cluster.
If it was it would be in KPH and wouldn't have SVT on the tach.
UK Mondeos have MPH speedos, Euro-spec Mondeos have KPH speedos. ST200 cluster(UK):
Martin
My Profile
2000 Contour SE V6 ATX 170K miles
Hecho en Mexico
Steel blue w/greystone interior
1997 Volvo 850 Wagon 146K
Posts: 3,816 |
Originally posted by Martin: Originally posted by pole120: Originally posted by Tony2005: I wonder if it could be a Mondeo instrument panel cluster.
[image]removed[/image]
Thanks for the pic! You verified something I've been trying to find out... Which was if the UK ST200s read to 150 (like a normal Mondeo) or 160 (like the SVT)... yay.
Also notice the brake/handbrake light is missing the word BRAKE?
