Posts: 69 |
'99 SVT Contour
Tropic Green
Stock
Posts: 21,653 |
About it having the traction control one, I think a couple SVTs did have it, but anyways I think it's on a lotta clusters whether the specific car has it or not. My cluster also has a 'sport' thing, but obviously it doesn't have sport mode.
As far as not having a check engine light... I guess Ford built you a perfect car and decided you didn't need it.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,345 |
I suggest getting it scanned right away to get the codes. If it is just missing the bulb assemblies, then you should be able to pick up some from Ford. In addition, are you getting a "5 beep pause 5 beep" sound when the car is running. If you are, then the airbag diagnostic module has determined a problem with the airbag. Could be something as simple as the bulb being burned out.
Bulb with assembly F5RZ-13466-BA $3.24 each.
Edit. Check Power Distribution Box next to battery to see if any fuses are missing (especially Fuse 11 KAM for the PCM).
1996 V6 ATX 96K miles
Posts: 21,197 |
I really wonder if you can add the traction control switch to make it functional like one other person has found. You might have a rare one. Not that traction control is a good thing. If you don't have I believe it's active all the time and you can't turn it off unless you have a switch. Take it out on a dirt road and see if the traction control kicks in when you floor it.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 69 |
Originally posted by Tony2005: I suggest getting it scanned right away to get the codes. If it is just missing the bulb assemblies, then you should be able to pick up some from Ford. In addition, are you getting a "5 beep pause 5 beep" sound when the car is running. If you are, then the airbag diagnostic module has determined a problem with the airbag. Could be something as simple as the bulb being burned out.
That's what is weird. I pulled the bulb for the airbag (which is acually a clear LED) and I did not get any beep from the module at all. I would think it should do that.
Also, I did check all the bulbs. The first two pictures I posted is with all bulbs removed and a light behind the cluster. Thanks for the information, though.
'99 SVT Contour
Tropic Green
Stock
Posts: 155 |
Is there anything in the Check Engine light area looking from the front side?
Greg
2000 Silver Turbo CSVT (((FOR SALE, PM me! $12K)))
1999 Vibrant White Cougar
Posts: 4,051 |
Both of your lower panels for the lights are different.
Even the fog light is different than any I have seen. Usually the fog symbol glows green, and no lighting around it. Yours is the opposite. Wierd.
Posts: 296 |
and the temperature don't say normal mine says and is a svt 98 i think maybe is a aftermarket gauges or something like that
Posts: 4,051 |
Originally posted by RRT_SVT: and the temperature don't say normal mine says and is a svt 98 i think maybe is a aftermarket gauges or something like that
98 say NORMAL, but 98.5-00 do not.
Posts: 69 |
Originally posted by TheFordGuy: Is there anything in the Check Engine light area looking from the front side?
Greg
No--it is just like a blank spot would be (totally black no letters)
'99 SVT Contour
Tropic Green
Stock
