Posts: 47 |
I changed the oil like a month ago, since then the car started to make that diesel sound when the car is cold, should i blame the oil for that sound, or what would the problem be. my car has the zetec engine, its a 2k
2000 Contour LX ATX
94,000 Kilometers (58,000 miles)
Posts: 5,143 |
sounds like the hydrolic lifters are starting to get noisey. Its not a problem, just an annoyance. at 58K miles... Seems like thats happening a little early. what oil are you using?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 21,653 |
It happens all the time. I've heard it on nearly new foci. Some zetecs are noisier than others. Be sure to use 5w-30 (synthetic preferred).
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 47 |
well, right now im using quaker state high mileage oil (not syntetic) should i change to syntetic???
2000 Contour LX ATX
Posts: 21,653 |
I would. Use mobil1 or another true synthetic (amsoil, red line, royal purple).
98.5 SVT
Posts: 5,143 |
Originally posted by Kremithefrog: I would. Use mobil1 or another true synthetic (amsoil, red line, royal purple).
completely disagree. You really only get the benefits of a synthetic oil if you use it right from the start of an engine's life. You also risk damaging the seals on your engine by making the switch to synthetic (thats a big maybe though). Synthetic blend is the way to go on higher mileage engines.
TEIN H.Tech Springs
Posts: 47 |
well, today when i was leaving to school (early in the morning) i turned the car on, and voila!! no diesel sound anymore, i dont get it, cause its been there parked all the night. then when i left from school, the car was cold again, and no sound!!! wow, i cant believe it, it fixed by itself!
2000 Contour LX ATX
Posts: 21,653 |
Originally posted by AliasJerk: Originally posted by Kremithefrog: I would. Use mobil1 or another true synthetic (amsoil, red line, royal purple).
Haha.
Go do your homework.
Fordfan, glad you don't have the noise any more. If it was truly the lifters and it happens again, don't get too worried. Like I said, it's pretty normal.
98.5 SVT
Posts: 1,224 |
Only pre-98's had hydraulic lifters. Your 2000 has solid lifters just like the Focus.
Double check your oil level. If it continues, go get a cheap oil pressure guage. Test it on a cold start. You should built some pressure immediately. Starving your head for oil is bad.
If it is really as loud as a deisel, you should be VERY concerned.
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 47 |
Originally posted by ButtonPuncher: If it is really as loud as a deisel, you should be VERY concerned.
BP
nah, it wasnt as loud as diesel, it just sounded like that. i think its time for my oil change, now my car has 60k miles, but i have always used conventional oil, never synthetic, should i try synthetic this time??? thank you
2000 Contour LX ATX
