Posts: 59 |
On my past stangs and Lighting I am right around 20k for all mods and misc stuff. And already in the tour I am about 1k into it Unfortunetly it will never end, the fast bug will go on.
98 CSVT E1
Previous Rides
03 Cobra
544rwhp & 585rwtq
10.89 at 135
97 Mustang Cobra P1SC intercooled
460rwhp & 412rwtq
11.47 at 120
89 GT w/347 mid 12's
99 Lightning mid 12's
95 Cobra Low 12's
I'm a sucker for speed
Posts: 777 |
easily close to $4,5000 in mods. between the svt body kit + paint, brand new E1's and tires from tire rack, front brakes, front & rear strut braces, gray leather interior( from wrecked doner contour)upgraded stereo, speakers, amp & cd changer, engine mods + dyno tune, hi-flo y pipe, cat, magnaflow res, mufflers, pass. side hanger and custom bend/install, and misc. stuff. damn maybe I spent more than that .
"we aren't punished for our sins, but by them"
2000 se sport tropic green/gray leather.
V6,svt body kit and E1 wheels/Avon tech m500 rubber, many mods.
2003 Eddie Bauer Explorer V8
2001 Suzuki Bandit 1200S
1996 Mercury Sable
Posts: 3,637 |
Intake- 100 Catback- 780 Headers- 500 Foglights/silvertars/clear corners- 130 Subframe Connecters- 150 Pretty decent spending for me having the car for 2 months
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 2,369 |
Way too much into the SE.
Only about $100 into the SVT so far. Got some decals, streetglow bulbs and Mobil 1 into it. Darker tints is next!
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Learned patience the hard way
Posts: 2,454 |
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 7,431 |
Originally posted by Buckshot77: Trump card- $25K+
Post your list man! I always enjoy seeing it.
Posts: 2,454 |
As requested:
Suspension Modifications
Koni Adjustable Struts Eibach Lowering Springs front H&R Lowering Springs rear 24 MM Aussie Bar- Rear Sway Bar ?¼ Metal sway bar backing plates Poly end link bushings ES Motor Mount Insert 225/45/17 Firehawk SZ50EP Tires on SSR GT1 rims for street 225/45/17 Kumho Victoracer V700 on Kosei K1 Racing rims for open track 225/45/17 BFG Drag Radials on Kazera rims for drag strip 5 MM spacers at wheels Tubular Steel Adjustable Rear track arms by Buckshot Motorsports Energy Suspension Rear Control Arm, Front and Rear Sway Bar bushings Urethane filled rear roll restrictor 12.2â? Superlite Brake kit from TCE Performance 11.25â? Upgraded Rear Brake Kit from TCE Performance Cryo Treated Brake rotors by 300 Below Inc. Adjustable Front camber kit from BAT Inc.
Drivetrain & Performance Modifications
Buckshot Motorsports prepped 3 liter block SVT Cams, w/ water pump drive removed Cunningham Chrome Molly Rods with upgraded rod bolts Diamond Racing 9.5:1 pistons with Total Seal piston rings Clevite 77 rod & federal mogul main bearings Dual Mode Mondeo Damper SHO Shop lightened Billet Flywheel Crank Knife Edged by Horn Race Engines Engine Balanced by Midstates Machine Crank, and rods cryo treated by 300 Below Inc. 3 Liter Heads Port & Polished with multi-angle valve job by PNPheads.com Port matched UIM and LIM SPEC Stage III clutch and pressure plate 2000 Model Year Transmission HMS Inc. Mark III transmission update w/ full lube system & Zetec Final Drive Ratio Quaife LSD installed by HMS Inc Driveshaft Shop Stage III CV shafts Cryo treated wheel hubs and studs 42 lb Ford Racing Injectors Walbro 255 LPH fuel pump MSD DIS-4 ignition Control Accusump 2 qt accumulator Remote mount oil filter Apex-I SAFC Magnecore plug wires B & M short Shifter 90 MM SCT MAF 65 MM Throttle Body optimized by Buckshot Motorsports. 2.5â? True Dual Exhaust w/ Magnaflow race series mufflers and crossover SCT Xcal2 & pro racer package tuning software Custom 1.75â? Nickel Plated headers by MSDS Inc Vortech Supercharger w/ upgraded shaft and Secondary bearing block on cross shaft by KnuKonceptz.com 2.6â? Supergrip pulley by Reichard Racing Custom water to air aftercooler by Buckshot Motorsports Autometer Phantom gauges including Oil Pressure, Oil Temp, Fuel Pressure, Boost/Vacuum and AEM Uego wideband O2 monitor 4 point Safety Harness Maximum Extrude Honed SVT upper intake Trunk mounted Optima red top battery with remote disconnect Mocal oil cooler and 180 oilstat
Aesthetic Modifications
Buckshot Motorsports polished stainless sill protectors Removed door ding guards Foglights run w/o head lights BNM Indiglo Gauges & HVAC Panel Powdercoating of Various engine pieces by Buckshot Motorsports Billet Pedal Kit including dead pedal 15% window tint Body color matched grilles at all locations Painted SVT Emblem at hood grille Custom Front Fender Badging PIAA 510 Driving Lights Front Splitter by Mirko Racing Carbon fiber cowl hood painted to match car Custom Paint
Sponsors
Brad Noon Motorsports Buckshot Motorsports Cunningham Rods MSDS Inc. Arizona Dyno Chip TCE Performance 300 Below Inc. Wolfeâ??s Auto Body
Buckshot77@msn.com
Posts: 710 |
heheh, wow! do you always have your list ready to paste?
morbid
2000 Contour SVT (black)
Posts: 2,454 |
I've got it as a word file that I just keep updated and can copy and paste if needed. Waaay too much to list off the tops of my head all the time.
Rick
Buckshot77@msn.com
Posts: 5,854 |
you got sponsors!? cheater!
1999 Silver Frost SVT
#609 of 2760
