Posts: 246 |
I have been on this board for a couple of years and the largest (width) wheels that I have seen are 8 inches. Anyone no of a tour that had 8.5 or 9 inch wheels. If so maybe you know the offset and tires combo used.
PICS WOULD BE AWESOME
'00 CSVT Koni/B&G (New), SCA intake, 18 inch Falken Circuit Spec (gunmetal), CF hood, Headlights by Dan, Mirko, deleted front license plate/painted chrome ring. Headers/y pipe installed - TruBendz Borla system no Res and optimized TB. Getting there!
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
I seen a mexican guy in down town detroit with atleast 12" rims or just massive spacers.
[censored] was b-a-n-a-n-a-s!
Posts: 540 |
I heard that was you
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
Posts: 7,025 |
A 8.5" wheel might fit, but thats really pushing it. I think the offset on my Axis 19x8 wheels are 42mm, and with my 235mm tires, they barely clear the strut. They do rub in the back as well. If you did run an 8.5" wheel, you would probably be stuck with running a tire less than 8.5" wide just so you dont the rub the fender and strut. Then of course, your tires look goofy since they looked stretched over the wheel.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 4,140 |
My guess is the most grip will be attained by a 17x7.5 and a 225/45R17. You might be able to squeeze a 245 on with an 8" wheel, but you'd have to watch the offset carefully, and probably roll the fender. Tire width is the real issue, getting enough wheel to put the tire on isn't.
Posts: 5,975 |
There's a pre-98 around here that has about 14" gold wire wheels that stick out a good 4-6 inches from the car. I imagine they must be about 11-14 inches in width. Add in an atrocious primered body kit and park bench on the trunk and it looks absolutely disgusting.
Posts: 246 |
BeyondLoaded. What if I had a 17'' wheel (8.5 width) with a 53mm offset. Any opinions?
Posts: 4,141 |
Originally posted by Aspire: BeyondLoaded. What if I had a 17'' wheel (8.5 width) with a 53mm offset. Any opinions?
Your tires would be all over your struts.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 7,025 |
Originally posted by pole120: Originally posted by Aspire: BeyondLoaded. What if I had a 17'' wheel (8.5 width) with a 53mm offset. Any opinions?
bingo...you wouldnt even be able to fit them to the hubs.
Jim Hahn
Posts: 246 |
And if I also had a 10mm spacer?
