I didn't read your post right the first time - I took it as if you had 9" discs, which are on the rear. The TCE website has bigger rotors, but also requires different calipers. Baer also has a kit (as does BAT). If you are in it only for the bling I believe the Baer kit is the lowest cost. If you want real man's brakes then get the Wilwood kit from TCE.
