Posts: 3,570 |
Originally posted by 96BlackSE: For the rod shift you need a lot of <PBBlaster> + <hammer>
x11tybillion. Took us 3 hours working on mine to get it loose, thinking of everything in the book and then some (like a sawzall). What a nightmare. It finally gave way. The rod shift trannies are nice but they sure are a bizzatch to get out
Posts: 5,810 |
Actually, I owned a 95 SE and I don't think the rod shift trannies are all that nice. They work, but were always much slower shifting and more balky. The shift feel is/was much better on a cable shift, comparing new to new that is.
Then of course, if your shift forks start binding the rod shift is better. However, replacing my shift forks brought back the like-new shifting and since I haven't used ATF anymore in my transmission, I haven't had anymore issues with binding forks. So I'd say that other than binding shift forks, the cable shift is superior in speed and feel. My Opinion after owning both types brand new.
See My Mods
Posts: 4,141 |
Got it out today, not too hard at all, I'll take pics of the chain arangement i used for those tht need it. I'll be picking up the other lifting eye bracket on my next trip to the bone yard.
Thanks to all, Josh
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 21,197 |
Started on my 4th pull today. Actually I did a bit of Bk's car too so I guess 4.5. They only get easier & easier the more you do them and figure out little tricks.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,910 |
Originally posted by warmonger: Actually, I owned a 95 SE and I don't think the rod shift trannies are all that nice. They work, but were always much slower shifting and more balky. The shift feel is/was much better on a cable shift, comparing new to new that is.
well having driven my fathers 95 which we got with 9k on it and my 95 LS which we got with 83k and compairing it to our 99s which we both picked up with around 60k on them I have to say the rod shifter has much better feel then the cable shifters. the rod shifter to me has a more positive, connect feel then the cable. stock for stock I really didn't notice a difference in shifting speed since the shifters are of similar lengths and similar in shape. now a cable shifter with the steeda shifter, as the second thing I put into my car is much improved. that is definately faster to shift but still lacks the possitive feel the rod shifter gives
- 95 Mystique LS - Zetec/5spd
Posts: 4,141 |
I snapped a picture of where i hooked the chain on the rear bank of the motor. I'll post pics tonight or tomorrow.
Josh
Totaled 02/12/06
Posts: 624 |
I know you've already got this thing out Pole, & I know i''m late to the discussion, but i've done this 7 or 8 times b/n the 3 tours i've got, all through the bottom. I'm going to add my opinion for the sticky, for the record i've never tried it from the top & probably never will, seems like too much work. BTW I've got 2 CSVT's both EO's both had the 2nd eyelet, my 98 SE doesn't. When I pull one I drop the radiator just to be safe, remove the strut tower nuts , remove battery box for room to maneuver, pull power steering resevoir off of firewall and tie to engine, fuel lines, throttle cables, various wires, drop exhaust, break mounts & subframe bolts lower struts & all. Then you drag it from under the car & work on the whole assembly where you have room. Sounds alot simpler to me. Of course, you have to bleed your brakes when you put it back together, but thats the only real diff. Remove bolts from front & rear roll restictors & lift engine & trans up slightly & pop axles out, careful not to overextend your axles, 18 degrees I think. I did all of this w/ 2 sets of jackstands, one set is homemade so they're taller, 1 regular floor jack, 1 cherry picker. I can have everything dropped out of this thing in less than 2 hours this way. 1st time I did it it took 6! If i get up to my dads shop I'll take pics of my SE, Its torn down like this right now. I'm not going to say my way is better, but to me it seems easier, & since my tours are falling apart I get alot of practice this way!
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
Posts: 21,197 |
How in the world can that be easier than seperating the ball joint, pulling the axles, disconnecting fuel lines and all electrical connections, dropping the rad. (optional) and removing the ypipe. Pulling it out the bottom is just insane to me w/o a lift. You have to realign the subframe, deal with power steering and brakes etc.
-'96 SE MTX 3L
Posts: 624 |
Its all a matter of opinion I guess there Todd, but the subframe alignment is not rocket science, & if you remove the power steering resevoir & place it on the engine then you don't have to fool w/ it at all. Brakes are no big deal either. You mean that you've never had to have a car realigned after pulling the ball joints & etc. Not to mention damaging the rubber boots on ball joints & tie rod ends. Pick your poison I guess!
Posts: 21,197 |
Originally posted by OB1: Its all a matter of opinion I guess there Todd, but the subframe alignment is not rocket science,
I know. You can use a deep well socket. I've done them when doing just the trans and hanging the drivers side down.
Nope. All you do is use an air hammer and seperate the split in the knuckle. Just grab a good pry bar and the bj will pull right down from the knuckle. For tie rods you just undo the nut and tap it up with a hammer. No damage to anything or need to realign.
-'96 SE MTX 3L
