Posts: 4,141 |
Originally posted by svt490: When I pulled the axles on my car, I used and axle pulle from autozone. It's basically a slide hammer with a "claw" attachment. You place the claw between the trans case and cv joint and slide the hammer repeatedly until it pops out. Make sure you have a 32MM axle nut socket, you can get those from autozone too.
Can't i just leave the nut on and leave the axle in the knucle
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 238 |
I guess you could, I didnt really think about doing it that way.
Mike C
T-Red 99 csvt #490 No longer a dailer driver
Learned patience the hard way
Posts: 2,454 |
You can do it that way, but you run a lot bigger risk of hyperextending the CV joint and popping out of place. Also, you'd still have to pull the knuckle loose of the lower ball joint to have enough play to pull the axle out of the trans.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 5,975 |
Posts: 9,065 |
Originally posted by Buckshot77: You can do it that way, but you run a lot bigger risk of hyperextending the CV joint and popping out of place. Also, you'd still have to pull the knuckle loose of the lower ball joint to have enough play to pull the axle out of the trans.
Rick
I know this is the wrong side, but I would simply get the strut and knuckle out of there and then get the widest ball joint seperator in between the trans case and the shaft...it should pop right out.
Posts: 460 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢:
I used a pic a fork
These are known as pickle forks not pic a forks!!  Karl
*** It's all about consistency! ***
*** Previously 88SVT ***
06 F150 Supercrew 5.4L FX4
98 SVT Contour #4362 Born 1/6/1998
86 Ranger GT (For Sale)
69 Fiat 850 Sport Spider (For Sale)
67 Formula-S Barracuda
Posts: 9,065 |
I've only heard it, never typed it out...never bothered to ask wtf anyone was saying...lol
Posts: 1,231 |
-06 GTO Torrid Red/M6
-98 LS with BPU
-05 Honda Odyssey EX-L
mv .zig ..\for\great\.justice
Posts: 9,065 |
Originally posted by Save Todras: That's a big f'n pickle.
That's what she said!!
Posts: 1,746 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: Originally posted by Save Todras: That's a big f'n pickle.
Still using that pickle cause you cant get it up eh? I told you man...thats what viagra is for. Just make sure you completely swallow it, if it gets stuck in the back of your throat, you'll have a stiff neck for hours.
I kid, I kid....
2000 Contour SVT
SF - #542 of 2150
