Page 3 of 9 1 2 3 4 5 6 7 8 9
Pole120 Offline OP
where did you get it? Do you know offhand what isex i need?
Do you have an AUtozone around? They will let you borrow one. I used them when I did my Springs and struts. Leave a deposit, use tool, return. Pretty cool, esp. for seldom used tools. Good luck.
Scott
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Pole120 Offline OP
What is it exactly that holds the axles in?
C-clip
Originally posted by todras:
C-clip
May want to consider replacing it as well. Or at least that's what I was told by Buckshot when I did my 3L swap.
C-clip
the c-clips on my re-man'ed axles sucked the big wang, had one fall out on me. Be cautious, make sure they've got a good fit going in.
Pole120 Offline OP
C-clip
So correct me if i'm wrong. I need to pull the c-clips then use a pickle fork to get the half-shaft out of the trans.
Thanks for the great info guys.
Josh
Huh?
Pole120 Offline OP
Anyone else doing it this way, or have another way of doing it, pulling the axles is realy the only thing i'm not positive i know how to do anymore.
I used a pic a fork
C-clip
So correct me if i'm wrong. I need to pull the c-clips then use a pic a fork (we call em pickle forks) to get the half-shaft out of the trans.
Hopefully that clears up my question.
Uuuu the clip is on the axle inside the transmission. How on gods green earth are you going to pull it? These aren't Contour axles but you get the point.
