Posts: 4,141 |
where did you get it? Do you know offhand what isex i need?
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 1,029 |
Do you have an AUtozone around? They will let you borrow one. I used them when I did my Springs and struts. Leave a deposit, use tool, return. Pretty cool, esp. for seldom used tools. Good luck. Scott
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 4,141 |
What is it exactly that holds the axles in?
Totaled 02/12/06
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,051 |
Originally posted by todras: C-clip
May want to consider replacing it as well. Or at least that's what I was told by Buckshot when I did my 3L swap.
Posts: 3,570 |
the c-clips on my re-man'ed axles sucked the big wang, had one fall out on me. Be cautious, make sure they've got a good fit going in.
Posts: 4,141 |
Originally posted by rkneeshaw3.0: Originally posted by CSVT1214: Originally posted by todras: C-clip
So correct me if i'm wrong. I need to pull the c-clips then use a pickle fork to get the half-shaft out of the trans.
Thanks for the great info guys.
Josh
Totaled 02/12/06
Posts: 21,197 |
Huh?
-'96 SE MTX 3L
Posts: 4,141 |
Originally posted by pole120: Anyone else doing it this way, or have another way of doing it, pulling the axles is realy the only thing i'm not positive i know how to do anymore.
I used a pic a fork
C-clip
So correct me if i'm wrong. I need to pull the c-clips then use a pic a fork (we call em pickle forks) to get the half-shaft out of the trans.
Hopefully that clears up my question.
Totaled 02/12/06
Posts: 21,197 |
Uuuu the clip is on the axle inside the transmission. How on gods green earth are you going to pull it? These aren't Contour axles but you get the point.
-'96 SE MTX 3L
