Page 1 of 3 1 2 3
#1485046 01/19/06 02:44 PM
9
What would cause a p0300 random misfire.p0302 cyl 2 misfire and a po303 cyl 3 misfire to happen.Just changed plugs and wires about a month ago.plugs are tight and wires are on good.But i still got the codes. please help...
#1485047 01/19/06 02:48 PM
sounds like you're coil pack took a dump. How many miles? Mine died at about 104K
#1485048 01/19/06 02:51 PM
9
my car has about 140xxx. any way to test or just repace it . and that would be why i get a lot less miles out of a fill up to right
#1485049 01/19/06 02:51 PM
Make sure you gapped it 0.050 inch and the wiring order is correct.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1039060&fpart=1&PHPSESSID=
In addition, what plugs and wires did you put in?
#1485050 01/19/06 02:54 PM
What brand plugs and wires?
These engines can be very picky, especially about store brand wires and certain brand plugs.
#2 and #3 are on the same half of the coil. It's a strong possiblity if the wires and plugs are not the problem.
Steve
#1485051 01/19/06 02:54 PM
Would be part of it. If that Coil is origional best guess says thats you're problem. I replaced mine with an Accell one I got used with very low miles for $20. Brand new they go for about $80. Autozone has a wells one for $43. Before you run out and buy a new coil pack though, what kind of wires and plugs did you use?
#1485052 01/19/06 02:55 PM
9
wires are cheap accel plugs are ford
#1485053 01/19/06 03:01 PM
yeah, check into you're coil pack then. I would give you my other one, but I replaced it with the accell one because it was defective. I would get a random misfire pas 4K rpm's. My origional coil pack died and quit firing one of the cylinders completely. I replaced it with a ford one which after a month started giving me random misfires on more humid days. Then I replaced it with the accell one... That one made me really happy
#1485054 01/19/06 10:43 PM
9
where is a good place to get a new accell coilpack
#1485055 01/24/06 09:11 PM
9
i got my new coil and about 5 miles into the test drive it set off a cel misfire 2 and misfire 3 has anybody got any other solutions before i take it to a place to have them run it on a computer.i replaced the plugs ,wires and now the coilpack.
Page 1 of 3 1 2 3
