Posts: 54 |
ok i just found (after 2hours of extensive searching) Mikes 3L swap thread. i think it will help me tremendously but i do have some questions to clearify what i have read. mainly about valve springs.
2.5 or 3L valve springs for the 3L valves. in the thread it says use stock springs. to me that could mean one of 3 different sets SVT, stock 2.5 or 3L my teacher questioned that too.
thanks
Posts: 54 |
oh one more thing...is there anything else i might want to save off of the 3L i begin stripping it next class period(monday)
ive got: block (duh!) valves LIM
TB? MAF?
Posts: 197 |
Originally posted by kscontourkid: ok i just found (after 2hours of extensive searching) Mikes 3L swap thread. i think it will help me tremendously but i do have some questions to clearify what i have read. mainly about valve springs.
thanks
I used the stock SVT springs. You have a non svt correct? If so, check them with a spring tension gague and use the heavier springs. I forget what the SVT springs were..... But (just a SWAG) I think that the 2.5 and 3l springs should be the same strength.
Another option is the ST200 springs. However, sources tell me that they are probably not any stronger than the SVT springs...
The ONLY 96 (engine) 3L
Build 'em fast. Spray 'em faster.
ricehatersclub.com
Posts: 702 |
The Spring Rate For The 2.5 SVT Valve Springs Are 153 Lbs And The ST220 Valve Springs Which...DO FIT, Are Rated At 163 Lbs. And You Can Get Them At Any Ford Dealership. Should Cost Somewhere In The Range Of 60 Bones To Own Them.
Sorry I Dont Remember The Part Number But You May Find It In The 3L Part Numbers Stickie.
As Far As Saving Some Parts Off The 3L, Id Save All Of The Sensors That You Can...ECT Sensor, Knock Sensor, Et Cetera.
Her Is The Link To The Valve Spring Part Number: Click This And Like It!!!
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 197 |
The Spring Rate For The 2.5 SVT Valve Springs Are 153 Lbs And The ST220 Valve Springs Which...DO FIT, Are Rated At 163 Lbs. And You Can Get Them At Any Ford Dealership. Should Cost Somewhere In The Range Of 60 Bones To Own Them. Sorry I Dont Remember The Part Number But You May Find It In The 3L Part Numbers Stickie.
I almost forgot! Yes save EVERYTHING from both engines untill you are up and running. Then save the sensors for the future. You'll probably never have to buy another sensor again!
~Mike
ricehatersclub.com
Posts: 751 |
PH -- are you afraid that your shift key will stop working if you don't press it at least once per word? It's unreadable.
Whirling dervish of FFOG.
Posts: 197 |
Originally posted by weargle: PH -- are you afraid that your shift key will stop working if you don't press it at least once per word? It's unreadable.
lol I never realized that untill you pointed it out.
ricehatersclub.com
Posts: 702 |
Originally posted by giddyup306: Originally posted by weargle: PH -- are you afraid that your shift key will stop working if you don't press it at least once per word? It's unreadable.
The Shift Key Helps Me Keep A Rythm While Typing And Allows Me To Type Faster With Fewer Mistakes.
CSVT E0 3L
Posts: 54 |
Posts: 751 |
Originally posted by Pale Horse: Rythm
Not so fast there ...
