Posts: 72 |
I did a search and found all kinds of info on how to fix the moose but does anyone know what actually CAUSES it? I didn't get it until about 80k miles.
After I cleaned the UIM/LIM, I started the engine with the air cleaner off. I heard the moose and found air flowing from the MAF out. I covered the MAF inlet and the moose stopped. Could it be too much ring blowby??
Any Ideas???
John
John Alessi
Torredor Red #1915 of 2150
Born 27Jan2000
G/S No serious mods allowed
1986 SVO Mustang
Posts: 3,637 |
what the hell is the moose?
Maybe im crazy but i dont think ive ever heard it, unless people are talking about that slight sound you hear after acceleration.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 674 |
I had that problem on my 96 but not on the 99 SVT. The sound is normally heard at idle. It is a low "fog horn" like sound. Very anoying when you pull up to a stop light and the people in the next lane look over at you like WTF!?!
As for what causes it exactly I cannot remember.
Posts: 95 |
Call me crazy but i actually dig the sound of the (cold) moose as i slowly drive thru the parking garage at work...perhaps mine is'nt as loud as others...but the (a/c) moose is a bit annoying when the compressor cycles on and off..
98 Silver Frost EO
90 Grand Am H.O. Quad 4 300,000+ miles
Posts: 5,345 |
Beside the throttle hang fix, the official fixes are here.
Left picture 97 fix (TSB 97-22-3 hose F8RZ9H308AA and gasket E83Z9F670A). Right picture looks like a combination of stock and 96 bagpipe fix.
http://www.woodfam.com/ryan/svt/20000101-svt-moose-01.jpg
Illustration 2 in this article shows the stock inlet tubing as "old style" and the 96 bagpipe fix as "new style".
http://www.mightyautoparts.com/pdf/articles/tt94.pdf
Throttle Hang.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=3
Moosing sounds like. http://www.sanpedro.com/sounds/foghrn10.wav
As explained by Rogerm60
Originally posted by Rogerm60: The moose, moosing, foghorn, loud humming, IAC ???
Let me give you my slightly over the top explanation.
Have you ever held a microphone too close to the speaker on an amp?
Did you get a squeal? A hum? A throbbing sound?
Did the sound change when you adjusted the volume? The tone? Moved the microphone?
This is called positive feedback oscillation.
Our cars can also do this, we call it moosing.
Moosing is dependent upon acoustic phase and amplitude, and the timing of the electro-mechanical feedback response.
Primary acoustic waves come from airflow reversion in the intake tract. The amplidude of these is dependent upon many things including static timing, RPM, exhaust scavenging, exhaust backpressure, intake velocity, compression, blowby, and intake air density. Secondary acoustic waves are produced when the IAC changes position causing a change in air pressure upstream of the IAC. Next we have the electro-mechanical feedback which consists of the MAF and engine speed sensors, the ECM, and the IAC which is the output device.
Under normal circumstances the ECM uses the IAC to maintain engine speed by controlling airflow into the engine. If the engine speed is too high the ECM closes the IAC to slow it down, and if the engine speed is too low the ECM opens the IAC to speed it up. At the same time acoustic waves are changing the short term airflow past the MAF. Fluxuations in the airflow past the MAF cause fluxuations in the A/F mixture, which affect engine speed. Small changes in the mixture affects engine speed even more when the engine is cold. If the two feedback systems coincide to reduce or increase the engine speed too much, overshoot will occur. If the acoustic resonance of the intake duct and the electro-mechanical feedback resonance overlap, uncontrolled oscillations between increasing and decreasing overshoot will occur. This is typical moosing and it usually goes away as the engine warms up and becomes less affected by the exact mixture.
Ford has made two attempts to fix the moosing situation. First they experimented with different resonators between the IAC and the main intake duct. These are meant to change the resonant frequency of the duct to be outside of the moosing frequency, and dampen the amplitude of the acoustic wave before it affects the MAF sensor. The second attempt was to change the response speed of the IAC so that again, it would be outside of the moosing frequency.
Why do SVT's have this problem so much more often than ATX's? The SVT has both more cam overlap which causes stronger reversion pulses, and an MTX which is lighter and allows faster change in engine speed.
Why does the TH fix usually stop moosing? By limiting the IAC's ability to increase airflow it also limits the positive overshoot and thereby dampens the acoustic amplitude below the threshhold of oscillation.
The cure for moosing is to break the pattern of positive feedback. On the upstream end this may come from a change in the resonator design, a change in the IAC response speed, a change in the MAF response speed (they tend to slow down as they get older), the TH fix, or changing the distance between the MAF and IAC. On the downstream end everything from the intake manifold size and cleanliness to the exact exhaust configuration has some effect.
Since Ford has fixed it so that these cars do not moose when new, degredation of some component or components is responsible. You have the option of finding and fixing the responsible part (CAT's, IAC, MAF, engine wear, crud buildup...), reverting any modification that caused it (exhaust changes, CAI), or doing modifications to overcome it. Although the TH fix is popular and simple, it would be best used for limiting TH. A couple of people have had success in killing the moose by replacing the IAC supply hose/ resonator assembly with a couple of feet of coiled up plain rubber hose. Who can say what will work best for you.
I cannot help but note here that the resonator design on most other cars are both more elaborate and better integrated between the IAC supply and the main intake duct. Coincidence?
1996 V6 ATX 96K miles
Posts: 191 |
The above explanation should be in the FAQ. Good writeup! Mods, can we get it added to the Moosing article?
Current Ride: 1998 Contour SVT - T-Red, Res. Delete, K&N under the hood, broken side skirt at passenger rear jackpoint.
Its FOR SALE, see the classifieds.
Posts: 3,637 |
ive never had the moose i guess "knock on wood"
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 4,149 |
Are you the original owner?
-- 1999 SVT #220 --
Posts: 3,637 |
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 72 |
Tony,
Thanks for the info. Since this was posted before, I guess I missed it when I searched.
John
John Alessi
Born 27Jan2000
1986 SVO Mustang
