Posts: 1,746 |
I've got the key, and the tunes from Brent. Too bad the proggy says that the XGT1 processor code doesnt exist....
2000 Contour SVT
SF - #542 of 2150
Posts: 718 |
Originally posted by posthuman63t: I've got the key, and the tunes from Brent. Too bad the proggy says that the XGT1 processor code doesnt exist....
Well that sucks man!
How long did it take him...after you ordered to email you the tunes?
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 1,746 |
uhm...I paid in full on the 31st...got the stuff yesterday, today sent off and got my code to use the prggy and he sent the tunes the same time as i got the proggy opened...anyone else have a processor code error?
2000 Contour SVT
SF - #542 of 2150
Posts: 1,087 |
I got my tunes from Brent right away. I'm also having a processor error, though. It says processor code SFG2 is not found or something, plus when I hover my cursor over the tunes in the Open File menu, the details say it's for a 1987 Ford Mustang 2.0L  I emailed Brent about it, but it was around 4:45 ET so I doubt I'll get a reply until tomorrow
Matt
2002 Subaru Impreza WRX (WRB Stage 4+)
Old Rides:
1999 Sil-Fro SVT Contour 3.0L with goodies (Totalled 6/21/06)
1988 Bronco II (Sold)
You know you launch hard when you beat oncoming traffic through their own crosswalk lines.
Posts: 1,746 |
Originally posted by Bronco_SVT: I got my tunes from Brent right away. I'm also having a processor error, though. It says processor code SFG2 is not found or something, plus when I hover my cursor over the tunes in the Open File menu, the details say it's for a 1987 Ford Mustang 2.0L I emailed Brent about it, but it was around 4:45 ET so I doubt I'll get a reply until tomorrow
omg it does! Id rather have a 92 escort than a 87 mustang...ew. anyways...you have a pm!
2000 Contour SVT
SF - #542 of 2150
Posts: 1,087 |
Update: I just got a voicemail from Brent at Brenspeed. He said that the "1987 Mustang 2.0L" thing doesn't matter, but if you got your license number from SCT and it isn't recognizing your pcm code when you try to open the tunes he sent you, it's a problem on SCT's end. I'll be giving them a call a little later.
Matt
Old Rides:
Posts: 1,087 |
Another Update: I finally got it working after two new database files that SCT sent me. The database file (.mdb) is named with your four-digit "Racer Code" first and your four-digit PCM code second. They had my PCM code correct but my Racer Code was wrong on the original database and the first replacement, but it was right on the second replacement and now it works fine.
*Also a little heads up if you are getting a new database emailed to you: have the tech put the file in a .zip file to make sure your email client doesn't reject it as a malicious file.
Matt
Old Rides:
Posts: 1,336 |
Or you could use an email client other than Outlook/Outlook Express
Seriously though, thanks for the information guys ... I have yet to set mine up ... maybe next week
Posts: 718 |
Originally posted by Bronco_SVT: Another Update: I finally got it working after two new database files that SCT sent me. The database file (.mdb) is named with your four-digit "Racer Code" first and your four-digit PCM code second. They had my PCM code correct but my Racer Code was wrong on the original database and the first replacement, but it was right on the second replacement and now it works fine.
looks like i will be going thru this process tomorrow...mine will not recognize the processor code either!
1999 Cougar V6 MTX
Posts: 1,746 |
Yea, it sucks. but its an easy fix. Small file d/l. Ryan @ SCT can hook ya up.
2000 Contour SVT
SF - #542 of 2150
