Page 1 of 3 1 2 3
#1481516 01/15/06 03:23 AM
RRT_SVT Offline OP
i have changed to 3.0 block and svt heads in my svt and i have a superchip rjl1,ford racing wires, doble platinum plugs,pro-m racing 65mm maf,kkm intake i want to know wich is the better configuration for my exhaust i know the svt original have 2.25 buth i ear that a 3 will be a lot of difference i have removed the cats and modified a y pipe all with 2.25 with all the experience here in the forum wich is better i planned to buy the headres maybe in 4 or 6 months right now i only want to upograde my exhaust system
3.0 or 2.5 ???
thanks
http://www.cardomain.com/profile/svtmexicali Contour SVT 98 #1862 of 6535 born 06/11/1997 9.20 1/8 mile semi slick www.rudos-racing.com
#1481517 01/15/06 03:25 AM
9
3.0 or 2.5 ???
thanks
...????? you put a new engine in,and didnt do headers at the same time?...i dont understand..a 15 minute job vs a 6-8 hour job now..oh well,to your question...2.5" is more than enough...3 should only be used under extreme hp conditions
#1481518 01/15/06 07:40 AM
RRT_SVT Offline OP
3.0 or 2.5 ???
thanks
not only 15 minutes job is the monetary problem i installed thge 3.0 about 6 months ago after that was the tranny rebuilded then a month later the alternator right now the slave cylinder from the trainy that the prlobem when i am decided to buy the headers or have the money something happens i hope after this i will get the headers jejeje and the 2.5 exhaust changed
#1481519 01/15/06 03:29 PM
This is what i would say is the ebst bang for the buck and sounds amazing...
MSDS headers...you can get them for 200.
optimized stock y...I had mine done and welded a 2.5 pipe from the y to the rear where it splits into 2 parts again for about 60 bucks. I think you could stop after that. Then you have the
headers to optimized y...2.5 all thw way back where it splits to 2 2.25in and the SVT mufflers flow pretty well.
98 E0 SVT with some stuff
#1481520 01/15/06 03:31 PM
W
W
If i were you,
I'd save for the Torsen LSD AND the headers so that when you pull the engine and transmission out it will be the last time!
Get the WeaponR stainless, should be able to land them for about $400 and the Torsen about $550. Then installation of the Torsen, should be about $100 at most if you already have the transmission out at the same time.
As for the exhaust, Dual 2" pipes straight back to the rear of the car out through two mufflers and don't bother to use a y-pipe. Then sell the y-pipe.
Maybe you can find some headers used right now?
#1481521 01/15/06 07:18 PM
RRT_SVT Offline OP
i was in searching in ebay and don't find nothing no msds headers or type r you know where i can find? about 200 like you say?
#1481522 01/15/06 07:22 PM
RRT_SVT Offline OP
Originally posted by warmonger:
If i were you,
you say i installed a 2" pipes straight with that configuration i will gain hp and torque? from the low rpm or only in the high rpm???
#1481523 01/15/06 07:27 PM
Straight from MSDS you can get the headers only no coating for 200...mine were 220 shipped (I'm in UT...pretty close to CA) And the other headers are Weapon R.
Warmongers set-up would be better than the one I suggested, but as for price...mine's a decent amount cheaper.
#1481524 01/15/06 07:44 PM
RRT_SVT Offline OP
ok i don't try that option from msds i will try to get it and about the configuration they wil be a noticeable gain?? or only in the upper rpm range??
i am a little curious because i always have 4cyl cars and never do thatkind of configuration i hear that configuration for a v8 but never in a v6, here in the local mexican escene all the people first make the engine and trans te most powerful they can so i am a little lower over here i have win to a mustang gt 2004,jetta gli 92,jetta glx(vr6)97,neon sxt with turbo 5 psi, and a neon sxt n/a
i want my first to be very strong because the cars they win to me from the first they leave me back for about 2 cars so if that configuration give to me a better start i will do of course after install a quaife dif.
thanks for the help
#1481525 01/15/06 09:10 PM
hey do me a favor and pm me in Spanish...I need to brush up on it. I used lived in Mendoza Argentina for a couple years and I have forgotten a lot...so I need to practice.
Page 1 of 3 1 2 3
