Posts: 4,693 |
The Motorcraft finewires don't have platinum tips on the side wires so I don't believe that they work as well. Ford says they do work as well. Autolite has just started marketing their own finewire plugs. The correct part number for the one that fits out V6 is XP104. The Autolite finewire plug does have a platinum side wire. So far, the XP104 has been a bit pricy, but if they come down in price I will probably use it next time I change plugs.
As I said before, the best bang for the buck is the Autolite double platinum APP764.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 63 |
Originally posted by Big Jim: The Motorcraft finewires don't have platinum tips on the side wires so I don't believe that they work as well. Ford says they do work as well. Autolite has just started marketing their own finewire plugs. The correct part number for the one that fits out V6 is XP104. The Autolite finewire plug does have a platinum side wire. So far, the XP104 has been a bit pricy, but if they come down in price I will probably use it next time I change plugs.
I don't have a V6. I have an L4:
1999 Ford Contour L4-122 2.0L DOHC SFI.
I believe they would be:
Autolite Platinum Pro/Extreme Perform. XP5364 .050 OE Style
or
Autolite Platinum Pro/Extreme Perform. APP5344 .050 Use until inventory is depleted
Autolite Platinum Pro/Extreme Perform. APP5364 .050 Replaces APP5344
Posts: 4,693 |
I don't know the part numbers for the Zetec plugs. That sunds likely though.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 63 |
Originally posted by Big Jim: I don't know the part numbers for the Zetec plugs. That sunds likely though.
You can locate that info here:
http://www.autolite.org/
So, which plugs do I go with:
or
Posts: 63 |
I am guessiing I should go with the OEM Autolites?
Posts: 1,788 |
The OEMs were Motorcraft, not Autolites.
Just install EITHER the Autolites or Motorcrafts and be done with it. Both will work just fine.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 63 |
Steve
Hey Steve. If you go to http://www.autolite.org/ and search for 1999 Ford Contour L4-122 2.0L DOHC SFI, you will see they list:
As you can see, they are saying that the XP5364 are OEM type.
My question is...which Autolite to use?
The Autolite XP5364 or Autolite APP5364?
Posts: 410 |
In Canada, those plugs are called to run at 1.3mm I guess thats .050". I run DP's on all 4 cylinders on my Zetec. We are down to -20c at night right now in Manitoba. Cold? yes very. If your ignition system is not up to it, you are going nowhere. Same goes for the block heater if parking outside!
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
Posts: 4,693 |
Originally posted by Myrosia: Originally posted by projectSHO89: The OEMs were Motorcraft, not Autolites.
Steve
Use the APP unless there is little or no difference in price between the APP and XP. You will notice little or no difference in performance between them.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 410 |
I bought some Champion DP's a few months ago as a part store I frequent had a big sale. What's your take on these plugs?
180,500km's so far.
