Posts: 63 |
I want to replace my spark plugs. What are the best replacements for the best gas mileage?
Should I stay with Motorcraft OEM? Or the Autolite Platinum? What's the difference between single and double platinum?
I have a 1999 Ford Contour L4-122 2.0L DOHC SFI.
Thanks!
Mary
Ps. I have 100K miles, what's the best fuel treatment to clean the entire fuel system?
Posts: 1,119 |
double platium is the way to go. They are "double" platium as in two layers of platium. It is to make them last longer, and provide slightly better spark for the beging part of their life. Don't forget antiseize and di-grease. Check your autoparts store for packets before getting suckered into buying a bottle  I own a 12 oz bottle of antiseize which will last me after death.
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 1,119 |
duh forget fuel system.
-Replace fuel filter, search its on here, not hard, but watch your eyes.
-replace air filter
-You're doing plugs, maybe wires if they aren't in good shape
-fuel injector cleaner
thats probably the best start right there.
Trubendz Exhaust
Custom Hood
Posts: 63 |
Thanks for the respone!
Although, you didn't suggest to go witg Motorcraft or Autolites?
Also, my lifters are making noise like clicking noise. How to I clean the lifters form sticking?
Posts: 536 |
when was the last time you had your oil changed. if its been a while have it changed. the lifters tend to click/tap when the oil is old and dirty.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 2,659 |
New plugs/wires fuel filter Transmission flush Air filter Cleaning of MAF sensor Oil change Proper inflated tires
Thats about it.....good luck.
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 4,693 |
Originally posted by ZeroHour: double platium is the way to go.
They are "double" platium as in two layers of platium. It is to make them last longer . . .
Double platinum means that there is a platinum disc on both the center wire and side wire. Double platinum is essentual on your type of ignition system. The platinum tip is needed on the firing tip. Half of the cylinders fire the plugs in the conventional manner from the center wire to the side wire, and half the opposite from the side wire to the center wire. The original factory plugs had two different pat numbers, both single platinum, one part number with the center wire platinum disc and the other part number with the platinum disc on the side wire. To make the replacement plug "idiot proof" so that you could not accidently install the wrong plug in the wrong hole, they use a platinum disc on both the side wire and the center wire.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 63 |
Ok...then if they are only for extended life of the plug. I don't care about double platinum then. I can buy the Autolite single platinum for half much cheaper.
Ie.
Single platinum: 6 plugs for $8 Double platinum: 6 plugs for $24
Since I already invested so much money in the car this past year, I will go with the single.
Ps. FYI, I just replaced the O2 sensor upstream and it cost $130. I also use the Mobil 1 5W30 synthetic oil...another costy investment. I have new wires, ect ect.
In addition, I still get that ticking noise. It sounds like the lifter(s) are sticking, how do I correct that without major overhaul?
Posts: 4,149 |
Next change of plugs at 200k, priceless.
Why the f--- are you sweating $16 friggen dollars for something that should last 4 or more years versus something that could cause problems in mere months?
Originally posted by Myrosia: Ps. FYI, I just replaced the O2 sensor upstream and it cost $130. I also use the Mobil 1 5W30 synthetic oil...another costy investment. I have new wires, ect ect.
If you don't like having to do maintenance maybe you should take the bus
Your car has 100k miles, it REQUIRES maintenance.
-- 1999 SVT #220 --
Posts: 63 |
bigMoneyRacing...I appreciate you responding but not in that tone of voice.
FYI, I have the Motorcraft platinum right now. The original from when I bought the car. They have 100K miles on them right now....hmm...any problems?? NO....priceless...yes, I think so. They merely need to be replaced per maintainence!!!
In addition, perhaps $16 in nothing to you...but for some of us other unfortunates, every penny counts. Obviously, you've never gone hungry!
