i used some headlight plastic cleaner that worked quite a bit when i used it repeatedly.
but what works best? most of the yellow is gone, but not all of it.
thanks
'96 Mystique (Performance Wht/Zetec) few mods '65 Ford Mustang V8 <3 '85 Caddy Eldorado AKA Pimpmobile lol :P
This yields the best results, from what I hear.
Black 1998.5 3L Oval Port Full HMS Transmission Lots of other stuff Ressurected 06/14/06
F
F
Remove headlights from car or mask off car body, Wetsand them, with fine sandpaper (1000, 2000 grit) buff and buff with compound then I used Meguiars cleaner step of their wax system repeatedly and then once shiny, use tire shine as needed. Try e-bay, new ones are not too pricey for the older tours.
as long as you don't buy the "depot" brand headlights from ebay.. those are JUNK
fitment issues, poor quality, etc.
though for pre-98s I am not sure if they offer them at all.. so you'll have to see.
9
Does anyone buff with a power wheel or just by hand? I've done my lights twice by hand but can never get them as clear as some of the examples I've seen on this site.
Karl
*** It's all about consistency! *** *** Previously 88SVT *** 06 F150 Supercrew 5.4L FX4 98 SVT Contour #4362 Born 1/6/1998 86 Ranger GT (For Sale) 69 Fiat 850 Sport Spider (For Sale) 67 Formula-S Barracuda
yea dont do what I did..I've been through 4 sets of depots just to get the right fitment..now on my current set, the passenger side it perfect, but the driver side sticks out, kinda..oh well..im used to it
9
Karl
i used a power buffer on my post98's...skipped the wetsanding part,just used some heavy grit wax and went to town,than i used meguiars platic polish,i've heard pete say he sprayed them with clear coat too?.
i got a 96 contour and have the same problem.. i got a can of Turtle Wax Polishing Compound and some old face cloths(the textured kind ) wet the fACE cloth and ring out the water... put some paste on it and rub into the plastic lense.. takes about 10 minutes each lens.... also you can use a bonnet on an electric drill to spead up the process... i use some silver tape to tape up the painted area around the lense so i would not take the paint off... and with the hood open... took about three tries to make them look like new glass... i cheated by also using some magnifiy goggles to see where the tarnish was still located on the plastic lense.... cost of Turtle Wax polishing compound was $1.79... enough to last for a few years.. if it dries out in the can you just add a little water to it to work it up again into a paste....
just regular turtle wax like the kind i use on the paint? cause i already have that in the garage, or some kind of different compund?
thanks
E
E
thanks
No, it's a polishing compound. There's some grit in it to make it abrasive. To do it a tad faster, use rubbing compound a couple times, then step down to a polishing compound, and finally to a polish then wax.
I've tried this method, and it helped some. The best results I've achieved have been from sanding, then using the aforementioned procedure.
~Eric
2000 CSVT Silver Frost: #942 of 2150 HID Projectors and Fog Light Mod, Optomized TB, MSDS headers 2003 Silverstone Z
