laz2447 Offline OP
Anyone know how to do this?...
'96 Contour GL
*Its Not Stock*
E
E
I assume you are talking about the front door. There is a little round piece that you have to pop off(in the middle of the triangle). There is a screw in it that you have to unscrew. After that, IIRC you pull and its off. The interior door panel might be holding it on.
It's been awhile since I took it off.
**EDIT** To get that little circle pastic piece(thing to get to the screw) out, I took a pin and slowly worked it out.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
Thats the way to do remove it alright.
Be careful of that little plug though. Its expensive if you mark it up too much. I took them off with a tiny screwdriver once. Cost me a couple bucks for that damn plug. Outrageous!
CM.
99 Mercury Mystique V6 Black
KKM, 9006 BV Bulbs, Painted Calipers, 16" Cougar Rims
Alpine 7894, CDT HD62DT front, CDT Coaxials rear, ,Mmats Pro 10's. POS amp. No RICE.
took out my plugs and left em out... i'm lazy maybe but its much easier to tear that bitc# apart smile
-Speed Demon- Matt
Black 2000 Contour SE Sport (duratec/atx)
got body mods?
all show, better than stock go smile
"I might be crazy, but I'm not stupid"
speddmn.com
On my first Contour when I was trying to remove those caps to upgrade the speakers, I f'ed up the sail panel. When I upgraded the speakers on my SVT, I knew better and opted to drill out the $2 screw caps rather than mess up the $30 sail panels (not sure what they really cost, but more than the caps for sure). Supposedly duct tape has worked for people, but they were in too tight for me.
-Louis
1998 Black E0 #3826, lightly modded
I used duct tape. It may not work at the first few attempts because of the greasy protectant or whatever you use to wipe off the plastic interior parts. However if you keep trying it with fresh adhesive batch for a while it will pop out. I've never bought any of those round cover while i removed my door panels 3-4 times with this method.
spincity
Oh i forgot to mention that the duct tape must be yanked up hard (one quick motion) after it adhered on that little round cover.
spincity
