Page 4 of 5 1 2 3 4 5
#1475347 01/07/06 12:29 AM
Originally posted by Y2KSVT:
Originally posted by Hdbngr8:
Get an oil analysis - that can tell you with better precision how far you can go.
Excellent advice! I'd personally change it right away on a newly acquired car, just to be on the safe side. Then change it at 3000 miles and send in the oil sample . They'll be able to give you a good idea of how long your motor can go between oil changes.
Mark
where do we send that into?
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#1475348 01/07/06 01:48 AM
Like they said.. blacstong labs.
www.blackstone-labs.com.. or.. www.black-stone-labs.com or something like that.. lol
Pay for an analysis (indepth or not..) and they send you a container... use it, mail it in.. and get your results back.
#1475349 01/07/06 05:03 AM
I've been doing my changes every 3-3.5k miles. My driving only slightly spirited and the oil seems to come out too dirty. Mind you the engine has only has 32k on it. I had the change done at a shop last time (its too bloody cold out!!!) and the tech showed me the old oil and again, darker than I would expect. He was telling me to flush the engine, I politely declined.
I seem to have read here that some CSVTs tend to dirty up oil quickly????
-Adam- 2k Silver Frost #939 - 36K Miles H&R + Koni + Mirko + Elky Mesh + Hella Optilux + K&N + LoTek + Mille Miglia EVO 17" + ADC T-28 Turbo + Magnaflow 3" S.S. + exhaust leaks + CEL light + more to come...
#1475350 01/07/06 07:01 AM
wont hurt to spend 2 bucks and get some engine oil flush. they have a 5 or 10 min flush. get it at a autozone. you just pour into your oil and run it for 10 mins then drain your oil.
#1475351 01/07/06 03:29 PM
I personally will not change my oil before 5000 miles. Usually once I hit 5000, I wait till I am home to do it. I've run it up to 7500 miles before. On that oil change I took a sample for Blackstone, and I plan on sending it in for an analysis and TBN reading once I have an extra $30 lying around.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1475352 01/07/06 05:02 PM
I like to keep it clean. I change it every 3000. But if you don't drive it hard you can wait as long as 7000 without doing any harm.
And I imagine that you already know to over-fill the Duratec by .5 to 1.0qt because of starvation on right hand turns.
00 CSVT Black/Midnight Blue 2.5L DOHC Duratec V6, 200HP, MTX-75 MODs: K&N Filter, SVT ovals, Autometer gauges, PIAA 510's, Alpine S-type FE/Pioneer R, Pioneer Premier Series reciever #603 of 2150 92 Cavalier 1.8L I4 (Beater)
#1475353 01/07/06 05:23 PM
For clarification:
overfilling by 1 quart would be 6.8 quarts, and would be starting to push what I would do.
Remember: spec is 5.8qts, not the "standard" 5 qts.
6.5 would be the most (safely) that I would recommend) (which I run at each change).
#1475354 01/07/06 05:24 PM
I used to do it at 4,000 but after the last analysis I'm going to start going 7,500. (with mobil 1 and K&N filter)
Jim
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats".--H.L. Mencken Bumper sticker, OXYMORON #65 - Liberal Thinker
#1475355 01/07/06 06:49 PM
Using engine flush once a year is a good thing to do to help prevent varnish ad sludge buildup in the engine and like someone said, it only cost a couple of bucks a can - just make sure you follow the instructions on the can. You're NOT supposed to drive around while the flush is in the motor, only idle the car!
#1475356 01/08/06 12:12 AM
ya sorry forgot to mention that. if you have it change by a shop or anywhere else maybe you can give the engine flush to them some will some wont depends on where you go. i do my own oil change i cant trust somebody to do mine.
