Posts: 126 |
Originally posted by ODC: Originally posted by Kyle Miller: the planet is only about 6000 years old, watch kent hovind videos at www.drdino.com for real truth and proof that evolution never occured, nor did the big bang!!
its simple physics that defy the theory of evolution, its actually just a way for people to take God out of this world!
Simple carbon dating methods already disprove that the Earth is only 6k years old.
carbon dating is way offf base, scientists posted a mammoth bone as being 2 million+ years old, and another bone from the same mommoth as 300 years, wheres the science in that?
1998 CSVT
KKM Intake
Bosal CatBack
SHO Shop YPipe
Magnacore
Superchip
I am a follower of the great "I AM"
Posts: 126 |
As Kent Hovind said :
Whenever the worldview of evolution is questioned, this topic always comes up. Let me first explain how carbon dating works and then show you the assumptions it is based on. Radiation from the sun strikes the atmosphere of the earth all day long. This energy converts about 21 pounds of nitrogen into radioactive carbon 14. This radioactive carbon 14 slowly decays back into normal, stable nitrogen. Extensive laboratory testing has shown that about half of the C-14 molecules will decay in 5730 years. This is called the half-life. After another 5730 years half of the remaining C-14 will decay leaving only �¼ of the original C-14. It goes from �½ to �¼ to 1/8, etc. In theory it would never totally disappear, but after about 5 half lives the difference is not measurable with any degree of accuracy. This is why most people say carbon dating is only good for objects less than 40,000 years old. Nothing on earth carbon dates in the millions of years, because the scope of carbon dating only extends a few thousand years. Willard Libby invented the carbon dating technique in the early 1950's. The amount of carbon 14 in the atmosphere today (about .0000765%), is assumed there would be the same amount found in living plants or animals since the plants breath CO2 and animals eat plants. Carbon 14 is the radio-active version of carbon.
Since sunlight causes the formation of C-14 in the atmosphere, and normal radioactive decay takes it out, there must be a point where the formation rate and the decay rate equalizes. This is called the point of equilibrium. Let me illustrate: If you were trying to fill a barrel with water but there were holes drilled up the side of the barrel, as you filled the barrel it would begin leaking out the holes. At some point you would be putting it in and it would be leaking out at the same rate. You will not be able to fill the barrel past this point of equilibrium. In the same way the C-14 is being formed and decaying simultaneously. A freshly created earth would require about 30,000 years for the amount of C-14 in the atmosphere to reach this point of equilibrium because it would leak out as it is being filled. Tests indicate that the earth has still not reached equilibrium. There is more C-14 in the atmosphere now than there was 40 years ago. This would prove the earth is not yet 30,000 years old! This also means that plants and animals that lived in the past had less C-14 in them than do plants and animals today. Just this one fact totally upsets data obtained by C-14 dating.
The carbon in the atmosphere normally combines with oxygen to make carbon dioxide (CO2). Plants breathe CO2 and make it part of their tissue. Animals eat the plants and make it part of their tissues. A very small percentage of the carbon plants take in is radioactive C-14. When a plant or animal dies it stops taking in air and food so it should not be able to get any new C-14. The C-14 in the plant or animal will begin to decay back to normal nitrogen. The older an object is, the less carbon-14 it contains. One gram of carbon from living plant material causes a Geiger counter to click 16 times per minute as the C-14 decays. A sample that causes 8 clicks per minute would be 5,730 years old (the sample has gone through one half life), and so on. (See chart on page 46 about C-14). Although this technique looks good at first, carbon-14 dating rests on two simple assumptions. They are, obviously, assuming the amount of carbon-14 in the atmosphere has always been constant, and its rate of decay has always been constant. Neither of these assumptions is provable or reasonable.
An illustration may help: Imagine you found a candle burning in a room, and you wanted to determine how long it was burning before you found it. You could measure the present height of the candle (say, seven inches) and the rate of burn (say, an inch per hour). In order to find the length of time since the candle was lit we would be forced to make some assumptions. We would, obviously, have to assume that the candle has always burned at the same rate, and assumes an initial height of the candle.
The answer changes based on the assumptions. Similarly, scientists do not know that the carbon-14 decay rate has been constant. They do not know that the amount of carbon-14 in the atmosphere is constant. Present testing shows the amount of C-14 in the atmosphere has been increasing since it was first measured in the 1950's. This may be tied in to the declining strength of the magnetic field.
1998 CSVT
KKM Intake
Bosal CatBack
SHO Shop YPipe
Magnacore
Superchip
Posts: 660 |
Originally posted by Kyle Miller: scientists posted a mammoth bone as being 2 million+ years old, and another bone from the same mommoth as 300 years, wheres the science in that?
Oh, OF COURSE. The first pilgrims that landed at Plymouth Rock were greeted by Otis the wooly mammoth.
"But God created fossils and planted them here to test our faith!!!!"
2000 SVT Contour -- SOLD! New car coming soon...
1980 Triumph TR7 -- Needs a new home...
Posts: 3,718 |
Originally posted by SalKhan: Originally posted by JaTo: Welcome to Christianity, where half of the rites are pagan-based, some of the law was borrowed from other suspect religions and societies and where EVERY Christian religion today has it's roots buried deep into the wells of Catholicism.
I can't believe I almost missed this! HA!
Pagans rule! I mean... they have to have Xmas don't they?
Well, it is the truth, but the difference with me is that truths such as these do little to shake my faith where as some see them as a blatant attack on theirs. I find that people looking for general guidance and direction in life through religion fare far better and are MUCH more level-headed than those that are desperate to find personal meaning, emotional stability, mystical guidance or utterly simplistic answers to life though it...
Religion is about guidance, not finite answers on every concievable level. Too many lose sight of this.
JaTo
e-Tough Guy
Missouri City, TX
99 Contour SVT
#143/2760
00 Corvette Coupe
Posts: 126 |
do you honestly mean to tell me that you believe that if a tornado ravaged an airplance cemetary that a jet fighter could be made from the rubble, all by chance?
ABSOLUTELY NOT!! There are way too many intricate parts that no matter how hard the wind wanted to put together, it can't. Same as evolution, except evolution has the explanation: TIME!!
If the tornado lasted long enough, it could happen. How stupid does that sound?!
1998 CSVT
KKM Intake
Bosal CatBack
SHO Shop YPipe
Magnacore
Superchip
Posts: 126 |
Originally posted by 00SVT: Originally posted by Kyle Miller: scientists posted a mammoth bone as being 2 million+ years old, and another bone from the same mommoth as 300 years, wheres the science in that?
Exactly, carbon dating does not work!!
1998 CSVT
KKM Intake
Bosal CatBack
SHO Shop YPipe
Magnacore
Superchip
Posts: 21,653 |
Are you seriously comparing a destructive force of nature to a scientific theory?!?!????
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 21,653 |
No, just you're understanding (or lack of) of it does not work!!
98.5 SVT
Posts: 3,718 |
Originally posted by Kyle Miller: do you honestly mean to tell me that you believe that if a tornado ravaged an airplance cemetary that a jet fighter could be made from the rubble, all by chance?
No. Do you honestly mean to tell me that you are trying to pass off aviation construction and atmospheric disturbances as a litmus test to how evolution is a load of bunk?
Back to the Etch-a-Sketch...
JaTo
e-Tough Guy
Missouri City, TX
99 Contour SVT
#143/2760
00 Corvette Coupe
Posts: 6,198 |
Wow, this thread really went to [censored]. But surprisingly, I didn't have anything to do with it.
