Posts: 7,025 |
im running 8.5:1 compression on my turbo 3.0L. Some are running 9:1. Theres quite a few that are running 10:1 or 10.25:1 without any problems.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 636 |
Does the 3.0L run 8.5:1 stock or did you swap out the pistons.
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 7,025 |
Stock 3.0Ls have 10:1 compression remember.  Im obviously running custom pistons.
Jim Hahn
Posts: 636 |
I don't know a whole lot about the 3.0L's. I know the SVT's run 10:1 and the non-SVT's run 9.7:1 Well it's not completely obvious, you could have put spacers between the block and the heads  ... not the best way to go, but it would lower the compression.
-Mike
98 Contour SVT
85 Camaro
Posts: 7,025 |
thicker head gaskets only drop the compression a couple tenths.
Jim Hahn
Posts: 352 |
Delete.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
