Posts: 7,025 |
im running 8.5:1 compression on my turbo 3.0L. Some are running 9:1. Theres quite a few that are running 10:1 or 10.25:1 without any problems.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 636 |
Does the 3.0L run 8.5:1 stock or did you swap out the pistons.
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 7,025 |
Stock 3.0Ls have 10:1 compression remember. ![](/ubbthreads/images/graemlins/wink.gif) Im obviously running custom pistons.
Jim Hahn
Posts: 636 |
I don't know a whole lot about the 3.0L's. I know the SVT's run 10:1 and the non-SVT's run 9.7:1 Well it's not completely obvious, you could have put spacers between the block and the heads ![](/ubbthreads/images/graemlins/crazy.gif) ... not the best way to go, but it would lower the compression.
-Mike
98 Contour SVT
85 Camaro
Posts: 7,025 |
Originally posted by CSVT#49:
Well it's not completely obvious, you could have put spacers between the block and the heads ... not the best way to go, but it would lower the compression.
thicker head gaskets only drop the compression a couple tenths.
Jim Hahn
Posts: 352 |
Delete. ![](/ubbthreads/images/graemlins/troutslap.gif)
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
