Posts: 951 |
What do I do about the remote wire when installing an amplifier in a car with a factory radio? It's a 2000 Ford Ranger, and I'm willing to bet that it doesn't have a remote wire coming off of the HU. Most people would say to hook the wire to the ignition wire, but unfortunately I don't know which wire that is either. Let me know people, I know there are geniuses on this board
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Posts: 1,017 |
don't really have a whole lotta help here, but just my $0.02, installing an amplifier for speakers w/ a stock headunit isn't worth the time, effort, or money.
1995 SE
2.5L V6/MTX
187k
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Hook up the REM to the Accesory wire under the dash
Posts: 951 |
Originally posted by platinum_drew: don't really have a whole lotta help here, but just my $0.02, installing an amplifier for speakers w/ a stock headunit isn't worth the time, effort, or money.
The only reason I'm doing this is because I'm taking the Ford Ranger back down to Cincinnati for school instead of the Contour, and I don't want to bother the HU.
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 8,445 |
isnt the remote wire the exact same thing as the power antenna wire? so if you were going to the factory HU, hook the amp remote to the power antenna lead.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 1,279 |
Any wire that gets "hot" only with the key on will work for the remote turn on. As Steeda mentioned the ACC wire on the HU would be fine
Previous Owner of 00 SVT Contour #1077/2150
95 Contour SE '01 3L
Posts: 1,017 |
Originally posted by ElKy: isnt the remote wire the exact same thing as the power antenna wire? so if you were going to the factory HU, hook the amp remote to the power antenna lead.
I did that on a friend's system once, and for some reason the amp stayed on and drained the battery when the car was off. both wires were blue, I just spliced the wrong one...put it on the antennae and problem solved.
1995 SE
2.5L V6/MTX
187k
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Can't use the power ant, Cuase it shuts off when a CD inserted,
and as Knu stated not only am i right but its the correct wire to use!
Posts: 951 |
Originally posted by KnuKonceptz: the ACC wire on the HU would be fine
got a guide that tells me the wires on the back of a factory cd player? 2000 ford ranger
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 330 |
two options... Hook it up to your running lights or tail lights. works good for mounting it in a trunk, but since your in a pick up, id just run a hot wire the the power wire and hook it up to a toggle switch. If you want you can even get 'cool blue ones'...Its nice so can shut off the sub/amp if you wanna just hear the door speakers..
97 V6 ATX 20,000 Miles
alpine cda 9811
Alpine MRV-F357
hifonics brutus BX2000D
2 Kicker L7 15
I NEED GREY LEATHER DOOR PANELS!!!!!!
Flip out monitor
PS2
Spr-175a
SPR-69LP
SPR-57LS
60 Ft EDEAD
