Page 1 of 3 1 2 3
#1470462 12/30/05 12:49 AM
What do I do about the remote wire when installing an amplifier in a car with a factory radio? It's a 2000 Ford Ranger, and I'm willing to bet that it doesn't have a remote wire coming off of the HU. Most people would say to hook the wire to the ignition wire, but unfortunately I don't know which wire that is either. Let me know people, I know there are geniuses on this board
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
#1470463 12/30/05 03:49 AM
don't really have a whole lotta help here, but just my $0.02, installing an amplifier for speakers w/ a stock headunit isn't worth the time, effort, or money.
1995 SE 2.5L V6/MTX 187k
#1470464 12/30/05 04:56 AM
Captain Impound Boy
Captain Impound Boy
Hook up the REM to the Accesory wire under the dash
#1470465 12/30/05 11:33 AM
The only reason I'm doing this is because I'm taking the Ford Ranger back down to Cincinnati for school instead of the Contour, and I don't want to bother the HU.
#1470466 12/30/05 02:09 PM
E
E
isnt the remote wire the exact same thing as the power antenna wire?
so if you were going to the factory HU, hook the amp remote to the power antenna lead.
#1470467 12/30/05 03:55 PM
Any wire that gets "hot" only with the key on will work for the remote turn on. As Steeda mentioned the ACC wire on the HU would be fine
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
#1470468 12/30/05 04:04 PM
I did that on a friend's system once, and for some reason the amp stayed on and drained the battery when the car was off. both wires were blue, I just spliced the wrong one...put it on the antennae and problem solved.
#1470469 12/30/05 04:05 PM
Captain Impound Boy
Captain Impound Boy
Can't use the power ant, Cuase it shuts off when a CD inserted,
and as Knu stated not only am i right but its the correct wire to use!
#1470470 12/30/05 10:00 PM
got a guide that tells me the wires on the back of a factory cd player? 2000 ford ranger
#1470471 12/31/05 08:11 PM
two options... Hook it up to your running lights or tail lights. works good for mounting it in a trunk, but since your in a pick up, id just run a hot wire the the power wire and hook it up to a toggle switch. If you want you can even get 'cool blue ones'...Its nice so can shut off the sub/amp if you wanna just hear the door speakers..
97 V6 ATX 20,000 Miles alpine cda 9811 Alpine MRV-F357 hifonics brutus BX2000D 2 Kicker L7 15 I NEED GREY LEATHER DOOR PANELS!!!!!! Flip out monitor PS2 Spr-175a SPR-69LP SPR-57LS 60 Ft EDEAD
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
