Thanks for the cards and letters!
I just tried spraying inwards (towards the door) around the check-strap - you really can't get the spray-wand inside the cavity there, although I certainly tried. Once completed, I worked the door back and fourth, but if there's any improvement, it's minimal. I am convinced the binding is from the check-strap - it really has a harsh, unnatural feel about it - almost similar to a sliding door that's off it's track.
If I pull the panel off, will it all be there easy enough to see and lube?
