Posts: 7,117 |
Stainless. Check pix below.
Just keep lookin' on Ebay. Another set will come up. Install should happen Sunday.
Posts: 980 |
Originally posted by TourDeForce: Install should happen Sunday.
And...?
2000 Mystique LS
Duratec 2.5L MTX
Posts: 7,117 |
Originally posted by Tisby: Originally posted by TourDeForce: Install should happen Sunday.
And...?
Install went just fine. Fit was good. The downsteam O2 has very tight clearance from the subframe, but if you push the lower tube toward the center of the car as you tighten things up you get better clearance. Articulation of the engine moves the pipe vertically anyway so clearance shouldn't be a huge concern for that O2.
The sound is not quite what I expected with the stock exhaust. It's a bit blatty & ricer-boy sounding. Gotta tone that down definately, but it demonstrates that I've got some exhaust velocity going now.
Initially, the cat looked OK, but on closer inspection I discovered that the catlyst material was getting clogged with carbon and/or other deposits. Hopefully, this will solve more than one problem for me.
Posts: 439 |
sounds like a magnaflow center res is in your future, the longer the resonator the more mellow it will sound.
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
Posts: 7,117 |
Originally posted by ohsigmachi: sounds like a magnaflow center res is in your future, the longer the resonator the more mellow it will sound.
Yep, that will be phase 2 of the quiet down. Phase 1 will be installing a cat. Sorry, it's the daughters car so I've gotta keep it totally legal.
Posts: 46 |
What are WR headers, is that a brand or does that refer to a specific car??? Just curious?
Posts: 7,117 |
Originally posted by chriseichman: What are WR headers, is that a brand or does that refer to a specific car??? Just curious?
WR = Weapon R
Frankly, the headers are just about the only thing from WR that I have observed to be of adequate quality.
