Page 2 of 4 1 2 3 4
#1469180 12/28/05 06:09 PM
my mondeo has broke 2 studs so far, luckily both on different occasions.
hope you get it sorted
BTW, what wheels are they please ?
www.m-p-g.co.uk was steventrace
#1469181 12/28/05 06:17 PM
Those are stock E0 wheels.
#1469182 12/28/05 06:19 PM
OK thanx
#1469183 12/28/05 11:03 PM
9
...did you check them in the 1500 miles? on aluminum wheels you should check about 100 miles after the install...
#1469184 12/28/05 11:15 PM
Ah man that totally sucks!!! Sorry to see that. The same thing happened to my buddies toyota camry Good thing you were not hurt!
#1469185 12/28/05 11:42 PM
H
H
Sorry to hear about ur car man!! I hope everything works out for u!!!
I reject your reality and substitute my own.
#1469186 12/29/05 01:32 AM
I don't mean to reiterate what Chris already said, but definately check the torque on the lugs after you get to your FIRST destination post-tightening, and re-check continually that same day out of healthy paranoia.
My lugs came looser than I'd like them to be after one drive post-retightening (two lugs on each front wheel took a half turn to re-tighten to spec). OK, so I'm not the strongest man on earth, but I'd expect them to be solid in place.
Hey, look on the bright side. Bmonje did a rotor slide from 65mph and half his rotor disappeared
#1469187 12/29/05 01:50 AM
Sorry to hear 'bout your problem . Hope you get it fixed without too many issues .
~~~~~~~ Phil Black & Tan 2000 SVT Contour #2137 of 2150 35,000 miles & counting !
#1469188 12/29/05 02:00 AM
Y
Y
I say unload the car after it is fixed, sounds like a money pit.
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
#1469189 12/29/05 02:05 AM
E
E
That same thing happened to me this year. I had just had wheel bearing replaced 3-4 days prior. I drove to work that morning (Friday) it was noisy on the way home. Drove around some with my son on Sat., and it was getting noisier (but I didn't realize what it was...) was planning on calling the shop on Monday. Pulling out of a drive-through and they went. Sheared off 3 of the lugs. Luckily we were going 2 mph, and the owner was so apologetic when I called him, that he showed right up with his tow-truck and fixed it within a couple of days. No charge, of course. My fender was only slightly damaged (which he did not fix).
We were lucky. I was 3 minutes from the highway.
I'm glad you are OK. It could have been worse.
MUST SELL - ECM computer new for a 98 V6 mtx + pats Now trolling in a Red Nissan 4 x 4
Page 2 of 4 1 2 3 4
