http://www.drivewire.com/performanceparts/intrax/mercurycougarcamberkits.html
Some guy on NECO found it. I'm guessing it's probably another knock off of the SPC kit.
1999 3.0L Cougar: 220fwhp and 200tq 2003 VW Passat W8 with 4 Motion AWD http://www.cardomain.com/ride/300644 PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
It probably IS the SPC kit.
The pic shown is for a Honda.
How do we convince GC to make real top-plates for us?
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
Make your own
Make your own
Hey, I'll get right on that.
http://www.ground-control-store.com/products/description.php/II=135/CA=7
That looks easy enough to adapt.....think outside the box. Couple more months and you guys will get a peak at just a small taste of some of the stuff i'm working on.
Easy for you, maybe. That's why I posted the link.
Here's a different approach:
http://www.ground-control-store.com/products/description.php/II=641/CA=6
Neither design ia applicable as our strut towers are NOYTHING like the regular towers with flat tops. The only way you could use camber kits like those would be to cut te tops off the strut towers and weld flat plates in place.
Originally posted by Stazi:
cut the tops off the strut towers and weld flat plates in place.
That would have been the plan.
A buddy of mine machined an extension that he bolted onto the top of the shock tower. Not only would this allow for a camber plate to be bolted to the top, but it allows for greater suspension travel.
98 3.0 svt: Sold
